oil premix
Old Jan 22, 2004 | 07:14 AM
andericus mack's Avatar
oil premix
If I nix the omp, what is the mixture of oil to gas
I need on premix?
forget it, found it in search.
Old Jan 22, 2004 | 02:52 PM
93BlackFD's Avatar
built my own engine
post results
Old Jan 22, 2004 | 09:59 PM
It would seem 1oz per gallon should take care of it.
A little more for road racing, or top end type driving.
I think 1 oz / gallon will do for drag racing, as heat
is not as much of a factor. A tuner I talked to concurred.
Old Jan 23, 2004 | 12:41 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Yes it is a 128:1 ratio for normal driving.
Old Jan 24, 2004 | 12:41 PM
BDC's Avatar
BDC
BDC Motorsports
128:1 is too rich for normal, street driving. Kick it down to about 3/4oz per gallon of fuel.
B
Old Jan 24, 2004 | 07:44 PM
Wargasm's Avatar
Weird Cat Man
According to "Rotary Engine" by Kenichi Yamamoto (pretty old, but VERY technical)...
You need around 1:150 for wide open throttle, and around 1:200 under cruising conditions. For highway speed cruise, the OMP on the test engine was running as high as a 1:250 ratio with good results. This was for a NON turbo engine.... just FYI.
BDC's suggestion of 3/4 ounces in 1 gallon of gas works out to approximately 1:170 (assuming I didn't make a math error haha). This would seem to be a good compromise for a street driven car which isn't floored at WOT all the time.
Personally, just in case you're interested.... I run the regular OMP on my FD plus I also run 1:256 premix as extra insurance.
Brian
Old Jan 25, 2004 | 02:55 AM
IveDogg's Avatar
premix
so if i run a premix i wll be able to block off my oil metering pump. what is a good premix like wargasm said 1:256 will lubricate my rotors. and how by premixing does it lubricate my rotors
Old Jan 25, 2004 | 01:37 PM
rotarypower101's Avatar
sdrawkcab
if you read it closely he is using 1:256 in supplementary to his regular OMP operations as a precaution if his ~10 old OMP failsor is being restricted.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
