Oil Metering Pump
Old Jan 2, 2004 | 02:32 PM
nelam's Avatar
Oil Metering Pump
After some research, I have came to the conclusion to eliminate my oil metering pump since it is leaking and all. I will be running MMO premix with 1oz MMO: 1 gal. gasoline ratio.
Is the oil meter pump blockoff plate on the FCs going to work on my SA22 with a 12A?
If not, I am thinking taking my OMP off, disconnect the linkage and plug the oil lines to the carb. properly, then JB weld the ports on the OMP unit and reinstall the sucker.
What's your opinion on that?
Thanks,
Nelson
Old Jan 2, 2004 | 06:13 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
this is but looking at your signature reminded me, isn't this the year where the SA becomes smog exempt?
Old Jan 2, 2004 | 06:47 PM
Jeff20B's Avatar
Lapping = Fapping
The OMP will explode.
Old Jan 2, 2004 | 07:12 PM
CrazyJoe12a's Avatar
I'm not sure if the FC block off plate will work. I know Mazda Motorsports sells one specifically for the 12a, but I just gutted mine and JB Welded the holes.
Old Jan 2, 2004 | 07:14 PM
inittab's Avatar
I read your email
The OMP will still be pumping and the oil's gotta go somewhere. It'll probably leaking worse than ever. Either, 1) get a rebuild kit from www.loweperformance.com and fix the pump or 2) remove the pump, put on a blocking plate and premix.
Old Jan 2, 2004 | 07:41 PM
wwilliam54's Avatar
it WILL run
i just set mine on its lowest setting and let it leak
Old Jan 2, 2004 | 07:42 PM
mazdaverx713b's Avatar
Have RX-7, will restore
here in ohio, the cut off date is 25 years. so, i have to wait until next year for my 1980 to be exempt. at which time i will get historical plates for it. for note, there are only 12 counties in the state of ohio that have to pass an emissions test. stupid e-check. glad i am not in one of those counties.
Old Jan 3, 2004 | 09:48 PM
nelam's Avatar
Good point!!!
What if I gut the interior of the unit and plug the outlet ports with JB weld? This way, I am just using the unit as a block off plate.
The sad thing is, I never took one off to see what's in there. I will do that soon.
Nelson
Old Jan 3, 2004 | 09:53 PM
nelam's Avatar
I wish!
Here in California, the car has to be 30 yrs or older in order to be smog exempted!
Nelson
Old Jan 3, 2004 | 09:56 PM
cdrad51's Avatar
30? DAMN!
Old Jan 4, 2004 | 05:22 PM
pratch's Avatar
Mazspeed.com
c'mon - 30 isn't that old
Old Jan 4, 2004 | 05:43 PM
Jeff20B's Avatar
Lapping = Fapping
I'm not even 30 years old yet, but both of my REPUs are a few months older than me. They'll turn 30 before I do. Wow, my '73 12A is already 30 years old.
Old Jan 4, 2004 | 07:54 PM
chairchild's Avatar
50mpg - oooooh yeah!
that'll work mate, remove the end plates, and the bolts holding on the adjustment arm. Remove a few more bits from inside it untill it's just a hollow tube
Old Jan 5, 2004 | 11:42 AM
nelam's Avatar
Thanks, I just got a used unit from a junkyard to play with too.
I am thinking maybe I can somehow modify the stock unit to pump in MMO instead of motor oil. I know there has an adaptor avaliable but it will be interesting if I can use the stock unit to pump in MMO.
Nelson
Old Jan 5, 2004 | 01:08 PM
wwilliam54's Avatar
it WILL run
Nelson
http://www.rotaryaviation.com/oil_in...p_adaptors.htm
Old Jan 5, 2004 | 02:17 PM
nelam's Avatar
I knew about this. Thanks though.
I am just not willing to give up $76 for that yet!
Nelson
Old Jan 6, 2004 | 03:02 AM
honegod's Avatar
what I am seeing in the adaptor, the main thing that costs is the extension for the drive shaft to the pump.
it looks like it needs the extension because the spacer has to be thick enough for a hose barb to screw into it.
I wonder if there is enough engagement with the driveshaft to allow a THINNER plate with a different hose coupling setup to fit between pump and engine, and still have enough engagement to reliably drive the pump.
how much torque does the pump take to run ?
I am thinking very little should be needed because the pump needs to pump very little volume at hardly any pressure.
same with the oil passage through the spacer plate, it shouldn't need to be large at all since there is very little flow.
Snoopy FD
Dec 8, 2015 01:45 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rotor_veux
Aug 31, 2015 07:49 PM
