Sponsored by: CARiD
rebuild question, I know it's stupid but maybe...
Old Nov 25, 2003 | 12:22 AM
Chimeron's Avatar
I'm looking at getting an 87 13bt that needs a rebuild and I have an 87 13b that's running fine except it's outa tune. I was wondering if I could use the internals from the non-turbo to rebuild the turbo. I know it wouldn't last nearly as long as a rebuild with new parts but I'm a little short on cash. Just let me know if there is anything that would cause a catastrophic failure. Also, where is the most inexpensive place to get an engine rebuild kit?
Old Nov 25, 2003 | 01:49 PM
Project84's Avatar
Open up! Search Warrant!
The non-turbo rotors have higher compression ratio than the turbo rotors. They could be used, but people don't do that too often. As far as rebuild kits, there is no inexpensive rebuild kit. Also, different sellers of the parts needed to rebuild an engine include different parts in there "kit" because there is no industry standard rebuild kit. Check out these web sites and you will see.
www.atkinsrotary.com
www.mazdatrix.com
www.rotaryaviation.com
Old Nov 25, 2003 | 01:57 PM
wwilliam54's Avatar
it WILL run
dp
wwilliam54's Avatar
it WILL run
you could also get a used jdm tII engine
is should plug right in
www.corksport.com
www.rotaryshack.com
Old Nov 25, 2003 | 02:14 PM
Project84's Avatar
www.nippon-motors.com used J-spec motors for $750
Old Nov 26, 2003 | 12:51 AM
black_sunshine's Avatar
If you just wanted to use the seals and springs, yes it works fine. You will NEED to buy an engine O-Ring set (for the water jacket) as a bare minimum and don't skimp out on getting some viton OCR rings, too.
Generally, if you surf ebay, Atkins rotary sells kits there relatively cheap (~$450 for the "rotor kit" and ~$200 for the gasket kit).
It would be very much worth your time and effort to buy a complete rebuild kit, that is, unless you enjoy re-doing things.
13
Jan 9, 2018 11:19 AM
SCinfidel
Sep 8, 2015 05:36 PM
rotor_veux
Sep 3, 2015 07:10 PM
