timing with msd 6
Old Nov 16, 2003 | 03:58 AM
timing with msd 6
woundering how every one set thire timing with msd 6 installed. does mechanical advance still work on leading ingnition?? or only traling. if it's doesn't, means when over 4000rpm traling advanced but leading stay.
vacuum advance is disabled.
Old Nov 16, 2003 | 02:40 PM
REVHED's Avatar
Hunting Skylines
Mechanical advance will still work.
Old Nov 16, 2003 | 06:18 PM
honegod's Avatar
doesn't the MSD box get its signals from the stock senders in the distributor ? { I don't know, that's why I ask }
if so, since the senders are mounted on the advance plate both leading and trailing should have the stock advance.
Old Nov 16, 2003 | 09:12 PM
i am still runing in my new engine, so i didn't rev hard. only till 4000rpm
but i feel a bit missing fire between 3500~4000rmp after installed msd...
Old Nov 17, 2003 | 12:00 AM
mwatson184's Avatar
holley guy
Make sure you have good power and ground to the MSD, and check all other connections while you are at it.
-Marques
Old Nov 17, 2003 | 07:46 AM
everything look fine~@@
Old Nov 17, 2003 | 12:05 PM
813KR$'s Avatar
TEAM MAZDA
The timing is still set like a stock ingnition set up. Do a search for paul yaws timing settings and that will tell you exactly how to do it.
Old Nov 17, 2003 | 12:56 PM
rhinor61's Avatar
Here is YawPower article on timing.
Make sure you print it off, cause I notice that Paul is deleting some of the old posting which include the MSD ignition installation.
http://personal.riverusers.com/~yawpower/pultime.html
John
Old Nov 17, 2003 | 08:37 PM
thanks, i'll have a try
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
MoTeC
Sep 10, 2015 07:58 PM
incubuseva
14
Sep 3, 2015 12:37 PM
