Turbo question...why use FC turbos?
Old Nov 5, 2003 | 07:20 PM
Makenzie71's Avatar
...94% correct.
Why do so many people who turbo FB's seek out the later S4/S5 turbochargers? Everything I've learned about them leads them to being a bit more complicated and slightly less reliable than larger, more capable, similarly priced turbos, like a T3, for example. They're also not that easy to come by in really good usable condition. I'm just curious as to why they seem to be the turbo of choice.
Old Nov 5, 2003 | 07:21 PM
680RWHP12A's Avatar
the exhaust housing is usally too small on a t3
Old Nov 5, 2003 | 07:22 PM
Makenzie71's Avatar
...94% correct.
well that makes sense.
Old Nov 5, 2003 | 10:32 PM
mwatson184's Avatar
holley guy
You have a nice cheap setup w/ those turbos. You can buy the turbo, exhaust manifold (will fit 12a w/ little modification), and it comes w/ an internal wastegate for around 200 bucks (or less).
-Marques
Old Nov 5, 2003 | 11:20 PM
FB II's Avatar
anyone make a flange so you could use a t3/t4 hybrid?
Old Nov 6, 2003 | 08:00 AM
QuagmireMan's Avatar
Registered Offender
-Marques
what where???? 200 for a turbo setup.... if you could tell me where to get that i'd do it in a second.
Old Nov 6, 2003 | 08:18 AM
nosajwrx-7's Avatar
Rotax, Rotaries & Turbos
A turbo and manifold is far from a setup. It is a good start but far from a setup. You will still need a fuel pump and regulator, a carb hat that will stay on and together under pressure, piping, oil lines, a good carb or FI system setup for boost, distributor work, and so on. An intercooler is also a plus. Your talking 1k plus for a finished project.
Old Nov 6, 2003 | 12:20 PM
mwatson184's Avatar
holley guy
sorry bad word choice i guess
Old Nov 6, 2003 | 03:52 PM
Registered Offender
you got me all excited but then i got the let down
Old Nov 6, 2003 | 05:08 PM
XLR8's Avatar
TII turbos are a cheap good start. Most turbo swaps are started with a Jspec so it is that much simpler. The stock manifold is limited by its internal wastegate. Even when ported, the wastegate and manifold are limited to what a TII turbo can produce. Note the S5 turbos flow a little more and are considered a upgrade when compared to the S4.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
