So, my turbo is bleeding. I need a bandaid
Old Sep 24, 2003 | 06:18 PM
expl0d's Avatar
So i to it to my uncles shop, and it was the first time this thing was on the lift. I've had a 7-5-7 boost pattern since i bought the car. I found oil all over the turbo. WE couldnt quite see where it was coming from
Im pretty sure this is where my leak is, any comments?
is this a "at home" fix or should I have it sent somewhere?
Old Sep 24, 2003 | 06:50 PM
spurvo's Avatar
don't race, don't need to
Probably blown turbo seals, get them rebuilt.
Old Sep 24, 2003 | 08:37 PM
expl0d's Avatar
Dealerships can do nothing right, less than 5k on these new turbos and somethings wrong.
I need to rebuild the turbos? how much can I expect to pay if i take it to kd or rx7store?
Old Sep 24, 2003 | 09:10 PM
911GT2's Avatar
The Power of 1.3
Don't jump to conclusions. The oil could be from one of the lines going to the turbo, and not the turbos themselves. The boost pattern could be non-oil related, and it could just be a problem with the control system.
Have you seen this page? http://www.autosportracetech.com/RX-...leshooting.htm
Go through some of the troubleshooting things in there before you start shelling out cash for new turbos. But if you must know, KDR charged me about $1400 to rebuild my stockers. That seems to be about the industry standard for rebuilding the twins.
Old Sep 24, 2003 | 09:12 PM
Mahjik's Avatar
Mr. Links
First, check the oil return lines for the turbos. They have a tendency to leak as they get older and they are usually not replaced when installing a new set of turbos by most shops.
Have you verified the boost restriction pills are installed? It's pretty strange that you are seeing exactly 7 PSI which is what you would see without the restrictor pills installed (basically the lowest setting you can have with the stock wastegate).
Old Sep 24, 2003 | 09:16 PM
expl0d's Avatar
I need pictures. a million people told me about the pills in the restricter lines. i need a site with pictures :\
Old Sep 24, 2003 | 09:18 PM
Mahjik's Avatar
Mr. Links
Here ya go:
Old Sep 24, 2003 | 09:46 PM
911GT2's Avatar
The Power of 1.3
Good call.
Old Sep 25, 2003 | 03:35 PM
expl0d's Avatar
So theres defintly no ball type things in these lines, i can squeeze them with no restriction.
Is this my problem??
Old Sep 25, 2003 | 03:55 PM
expl0d's Avatar
edit: pic
Old Sep 25, 2003 | 04:06 PM
spurvo's Avatar
Not to make you dig further, but on later turbos the restriction is actually built into the pressure source nipples. To check this, you can pull the lines off the upper connector (the pressure source), put a vice grip onto the nipple body (ouch!), and carefully twist the body out of the manifold. Then look down the ends of the nipples and look to see if they have a narrowing in them.
My 93 had it's turbos replaced by a dealership before I got the car. It seems to have been done in 94 (service records). I had no restrictors in the actuator lines, but did have the restrictions in the pressure source nipples. I had to drill them out to allow manual boost controllers.
Old Sep 25, 2003 | 04:25 PM
Mahjik's Avatar
Mr. Links
Yep, that is something else to check.
If you find that you require the pills (as most 93's do unless you have the same situation as spurvo had), you can order them from various places but here are the sizes you need:
Stock Pill sizes are:
Wastegate - 0.064in (Drill # 52)
Precontrol - 0.059in (Drill # 53)
http://store.summitracing.com/produc...earchtype=ecat
Old Sep 25, 2003 | 04:27 PM
expl0d's Avatar
how do I get it off, Kinda scared since theyre clamped on.
Old Sep 25, 2003 | 04:57 PM
Mahjik's Avatar
Mr. Links
If you have extra vacuum tubing laying around (and everyone should), just cut them off. If you need to install pills in there, you may as well replace the lines when getting new pills.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
