s5 12a problem
Old Aug 12, 2003 | 06:38 PM
clarksonrx7's Avatar
s5 12a problem
well i just got my manifold back from the machine shop. it looks great and fits perfect. the problem is however that the turbo housings hit the intake manifold so it wont go on all the way. i tried grinding it some but it will just look like crap and i dont think i can even grind off enough. so i need to either extend the turbo out some more. or get a new carb and intake , something like a weber or holley that has a simple intake that doesnt come out so far. Does anyone have a used carb and intake they wanna sell me?
Old Aug 12, 2003 | 07:12 PM
coldy13's Avatar
Yeah, shutup kid.
If you can find one, you can get the intake manifold off a 12a Turbo, it is a lot thinner and eaisly clears the TII turbo.
Old Aug 12, 2003 | 07:49 PM
great. does anyone know where i can find a 12aT mani?
Old Aug 12, 2003 | 10:15 PM
hornbm's Avatar
FD > FB > FC
could you please explain to me exactly what an S5 12a is?
Old Aug 12, 2003 | 10:20 PM
Mr BiG G's Avatar
I'll Apex YOUR Seal
is it an s5 with a 12a in it or is it an s5 motor with 12a manifolds
Old Aug 12, 2003 | 10:33 PM
coldy13's Avatar
Yeah, shutup kid.
He put a turbo from a S5 TII onto a 12a
Old Aug 12, 2003 | 10:35 PM
Mr BiG G's Avatar
I'll Apex YOUR Seal
thanx coldy....you would have to get custom headers for it ryte?
Old Aug 12, 2003 | 10:37 PM
coldy13's Avatar
Yeah, shutup kid.
No, just grind the exhaust paths and the bolt holes on the TII manifold inward to fit the 12a, works fine.
Old Aug 12, 2003 | 10:42 PM
Mr BiG G's Avatar
I'll Apex YOUR Seal
can the 13b n/a manifold fit onto a 12a and if so is it better than the stock manifold....cuz if i can grind the ports and bolt holes on a 13b Racing Beat header it would be better air flow than the 12a Racing Beat header wouldn't it?
Old Aug 12, 2003 | 10:51 PM
coldy13's Avatar
Yeah, shutup kid.
No, why would it flow better? They use the same size pipe for both of them. It probably wouldn't even work with a header, since they don't have the extra metal on them that the stock manifolds do.
Old Aug 12, 2003 | 10:58 PM
coldy13's Avatar
Yeah, shutup kid.
Also, turbo's don't use headers, headers are for N/A only.
Old Aug 12, 2003 | 11:16 PM
Mr BiG G's Avatar
I'll Apex YOUR Seal
oh...i thot turbo motor's have headers with a turbo mounted on them
Old Aug 12, 2003 | 11:56 PM
nlc1179's Avatar
lol
Old Aug 13, 2003 | 01:55 AM
fatboy7's Avatar
Got Boost?
Some kind of do look like headers, but they call them turbo manifolds.
Old Aug 13, 2003 | 02:12 AM
Mr BiG G's Avatar
I'll Apex YOUR Seal
ok thats the kind i've seen....thanx fatboy
Gufran
Old Aug 13, 2003 | 11:19 AM
kuhlrx7's Avatar
Unconfirmed
to get it to fit all you need is the flange from a header kit to use as a spacer and another gasket. go to the racing beat site or the mazdatrix site to get them. you may need to get the exhuast studs replaced with longer ones if not long anuff.
Old Aug 13, 2003 | 03:41 PM
for a blow through on a 12a i'd go with a weber dcoe side-draft carb......i hear the wrap around manifold works well with the t2 turbo and manifold.........plus i think there's a bunch of carb hats out for webers....old vw crowd is big on those webers..lol
Old Aug 17, 2003 | 09:23 PM
does anyone know where i can find a cheap carb and header like the weber? like a used one or something?
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
