N-Tech HI Flow Cat
Old Sep 11, 2001 | 06:51 PM
rx7eaven's Avatar
Question N-Tech HI Flow Cat
I looked at the N-Tech web page and their hi flow cat looks pretty nice. I do not understand what is meant by, "Comes with a plugged hole that can be used for the air pump with some modification. " Do I need to remove my air pump after adding this mod or do I keep it? I would like to install this myself. Any suggestions...
'94 rx7 blk. r2
fluidine radiator
hks turbo timer
autometer gauges
m2 downpipe
unorthodox pulleys (on order)
racing beat dual tip exhaust (on order) - they no longer make the painted, they are all ss
pettit ecu (on order)
Old Sep 11, 2001 | 09:49 PM
Viper jr's Avatar
I've been looking for a way to be emission legal without the airpump.
I sent them (N-tech) an email about that too a few days ago and have yet to hear back. I suspect that the hole needs to be unplugged and your airpump hooked up to it to avoid damaging it. I got an email back from RX7.com and he said that any cat you go with on the 7 needs the airpump hooked up or damage will occur to it because the rotary exhaust is much higher than a piston's and due to the amount of fuel that is spent.
Old Sep 11, 2001 | 10:13 PM
Badog's Avatar
Going on 4 years with my N-Tech with no air pump and the hole plugged. CAT flows very nicely, and the brick(s) look like they did when first put on (color change only).
Old Sep 12, 2001 | 08:26 PM
Viper jr's Avatar
That's encouraging to hear. Would you please post what your last HC, CO and CO2 readings were?
Old Sep 12, 2001 | 09:12 PM
evot23's Avatar
Classy
I spoke to Nick about the high-flo as I'm switching to this as well. He told me the air pump was not needed for the cat. The air pump only engages at low rpms anyway. Better to call him, usually easier to get a hold of that way.
Thank God emissions in FL are gone!!!
Old Sep 13, 2001 | 06:38 AM
maxcooper's Avatar
WWFSMD
I've got pics of the cat (including the plugged port) on my web site:
http://www.maxcooper.com/rx7/parts_info/cat/index.htm
Old Sep 15, 2001 | 01:56 AM
Tobal's Avatar
where can i purchase this cat. i know u can purchase it at N-tech.com but is there any other places where i can get it for. and also what other cat are highly reconmended? With this car is it possible to shoot flames with DP and Catback? just curious
Old Sep 15, 2001 | 08:34 AM
rx7eaven's Avatar
The site for N-Tech is www.n-tech.net and typically you need dp and mp for flames. This is just what I hear.
94 rx7 blk r2
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
