Deos anyone make a serpentine belt system for the 13B?
Old Jun 7, 2003 | 01:43 PM
asherwood's Avatar
Something that would look cool, is there one available?
Old Jun 7, 2003 | 01:50 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
I think atkins has something like that.
I saw it on someones car and is was nice
I will try and find it
Santiago
Old Jun 7, 2003 | 01:57 PM
1987RX7guy's Avatar
http://atkinsrotary.com/newengpr.htm
But it is only for the three pullies. not all of the accessoried.
Santiago
Old Jun 7, 2003 | 01:59 PM
CarmonColvin's Avatar
Atkins sells a Ribbed belt pulley kit. Not a true serpentine belt like an FD has but it is as close as you will get. I have one of them and love it. But unfortunately I am changing classes of racing and it is not legal for me to use in the new class.
PM me if you would like to buy it.
BTW: The kit only comes with the main pulley, water pump pulley and alternator pulley. You can't run an airpump, air conditioner or power steering pump with it.
http://www.atkinsrotary.com/newengpr.htm
^^^ scroll down towards the bottom of the page.
Old Jun 8, 2003 | 10:47 AM
asherwood's Avatar
I may be interested, but if this replaces the main pully how would you run the A/C and PS pumps?
Old Jun 8, 2003 | 11:41 AM
The kit is not designed to run Air Conditioner, Power Steering or Emessions Air Pump. This is pretty much a race only part because you cant run any of the accessories besides the alternator.
As I said: "BTW: The kit only comes with the main pulley, water pump pulley and alternator pulley. You can't run an airpump, air conditioner or power steering pump with it."
Old Jun 8, 2003 | 04:30 PM
$150FC's Avatar
Currently Winning
What advantage is there to running the serpentine system?
Old Jun 8, 2003 | 04:42 PM
It looks cool.
The wider belt gives better grip to the water pump and alternator and is not as complicated as the dual pulley system.
It does not have to be pulled as tight to get grip so it is supposed to be easier on the bearings of the alternator.
The belt lasts longer.
And I think it has less rotating mass than a dual pulley system.
Old Jun 9, 2003 | 01:01 PM
asherwood's Avatar
I wasn't implying using the serpentine belt for the A/C and P/S, just if it made it possible to run an additional pully on the main to keep these accesories alive.
But appearently not...too bad. I'm out
Old Jun 9, 2003 | 01:16 PM
jimmyv13's Avatar
Round&Round not Up&Down
What's your price on the ribbed belt kit?
Old Jun 9, 2003 | 03:47 PM
LS1FC's Avatar
LSX7
Correction.
1. It is a true serpentine pulley kit.
2. You can run all accesories with this kit, including the smog pump.
3. The stock pullies for the AC, PS, and smog pump will have to be utilized.
Old Jun 9, 2003 | 03:53 PM
mazdaspeed7's Avatar
mad scientist
Originally posted by Rotorlution
Correction.
Wrong. The smog pump goes off the water pump belt. So you could not run the smog pump with this pulley set. I am unsure if the stock pulleys for a/c and p/s will bolt onto the main serpentine pulley either. It may, but I wont know until I have a set(should be soon).
Old Jun 9, 2003 | 04:01 PM
Psychoblue23's Avatar
Can anyone recomend new belts. I just want to replace stock ones. 88 NA no mods, just lookign for a good set of belts.
- James
Old Jun 9, 2003 | 04:11 PM
LS1FC's Avatar
LSX7
Wrong again! Just buy an extra AC belt and run it directly from the stock pulley after the atkins serpentine (main crank pulley) to the smog pump. The ONLY reason Mazda has an extra belt running across the water pump is to reduce slippage of the belts at the water pump, not at the smog pump. For the record I do not have AC or PS but it will work with all three.
Forgot to mention that the smog pump belt also goes around the main crank pulley, not just the water pump. Not sure if I made that clear enough above.
Old Jun 9, 2003 | 04:20 PM
mad scientist
It wont line up genius.
Old Jun 9, 2003 | 04:32 PM
LS1FC's Avatar
LSX7
Oh I see...Now you're gonna be a dick and try and knock me because I just educated your *** "genius"
Funny how the system works on my car. Funny how your dumb *** thinks the smog pump belt runs around the water pump pulley only. Dude, you gotta alot of nerve calling me genius. Practice something new, comment on what you know, not what you think you know.
Old Jun 9, 2003 | 06:41 PM
mad scientist
The air pump is lined up with the outer of the 2 belts on the water pump pulley. The serpentine pulley kit replaces both of those belts. If you add a pulley to the main pulley, the smog pump pulley will be in its normal place, but the main pulley will be sticking out farther, and they wont line up. It may work, but the belt wil be pulled at an angle, and not work well. You should take your own advice. The smog pump IS run off one of the belts driving teh water pump.
Whats the point of using that kit if you still have the smog pump and a/c and p/s anyways?
Old Jun 9, 2003 | 06:42 PM
mad scientist
And why dont you post a pic of your pulley setup?
Old Jun 9, 2003 | 11:18 PM
Correction.
A true serpentine belt system has an idler pulley and pulleys that run on both sides of the belt somwhere on the system. And even Atkins website just calls it a ribbed belt system. Nowhere do they call it a serpentine belt system.
If you are having to use stock parts to run the accessories then how are you running "all accessories with this kit", stock parts are not part of the kit.
Please post a picture of your pulley setup I would like to see how your AP pulley lines up with the main pulley on the front of the Atkins pulley.
Old Jun 10, 2003 | 01:06 AM
LS1FC's Avatar
LSX7
Here we go again.
1. The atkins belt (in this case a Gates 6 groove ribbed belt) is identical to ANY belt used on what YOU would call, a "true serpentine" pulley system. However, some (most) serpentine system's use a 4 groove belt providing even less contact to the surface area. This may be true with an FD's serpentine system but I honestly havent looked. Maybe an FD owner can chime in and give us some input.
2. True, most serpentine systems use a spring-loaded pulley (idler pulley) that maintains tension on the serpentine belt. The reason for this is for doing away with the need to retension the belt when it is replaced. Thats all!!!
3. It is called a serpentine belt because of the way it snakes around the various pulleys. However, on our cars there is no need to do that as it is a strait shot. This of course is ideal, as the more pulley's the belt wraps around the more drag that occurs.
As you can see, the atkins pulley kit is just as good if not better then the traditional serpentine pulley kits out on the market.
I will admit that when I purchased the kit I wasnt concerned with smog, that has since changed. I also have no AC/PS but I still maintain that the kit will work with those accesories as well. Call Atkins if you dont believe me.
But I guarantee you this belt is identical to 95% of the serpentine belts out there, with the exception of it being a 6 groove, which of course is better anyway.
Old Jun 10, 2003 | 01:09 AM
LS1FC's Avatar
LSX7
And when I get a digital camera I will gladly take pics and post them for you guys.
Old Jun 10, 2003 | 10:26 AM
No more messages please.. the pulley kit is sold.
Old Jun 30, 2003 | 12:20 PM
rgordon1979's Avatar
LS what?
www.revolutionrotary.com
Old May 10, 2004 | 03:26 AM
jhillyer's Avatar
This ghetto site is dead.
Old May 10, 2004 | 05:36 AM
gildardo's Avatar
FC Revolution
that was like a year ago.
LunchboxCritter
15
Jan 3, 2016 04:11 PM
Machupicchu
Aug 17, 2015 08:27 PM
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
