TURBO Q's???
Old May 16, 2003 | 05:15 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
TURBO Q's???
Will a TURBO 2 exhaust manifold(without the turbocharger) fit on a
GSL-SE exhaust ports??? or is it better off getting a custom exhaust manifold for a turbocharger(of choice)???
Can the N304 handle as more air comes in through the AFM???
2x680cc of fuel injection should be able to handle at least 4 pounds of boost right??
Old May 16, 2003 | 06:00 PM
Felix Wankel's Avatar
Super Newbie
You'd be able to bolt the exhaust manifold on, but the turbo probably isn't going to clear the 6 port actuators or the lower intake.
Old May 16, 2003 | 06:26 PM
web777's Avatar
You will need to grind the manifold since the SE engine has a block on the center housing between the ports. See http://www.winisp.net/gsl%2Dse/turbochronology.asp.
Old May 16, 2003 | 07:03 PM
moremazda's Avatar
Gone Race'n
Broken link!!
Old May 16, 2003 | 07:12 PM
Pedestrian X's Avatar
SpAz!
Originally posted by moremazda
Broken link!!
just remove the "." at the end of it..
Old May 16, 2003 | 07:13 PM
web777's Avatar
Old May 16, 2003 | 07:42 PM
eddierotary's Avatar
back with rotaries
you have to grind the manifold and the block to fit it and another thing too that the manifold and turbo wont fit with the stock gslse intake manifold.you have to use a ported turbo II intake manifold or a spacer toexend the turbo manifold
Old May 17, 2003 | 12:17 AM
MRGSL-SE's Avatar
where can one get a spacer???
when you say GRIND DOWN the MANIFOLD... do you mean the EXHAUST MANIFOLD and not the LOWER INTAKE MANIFOLD... or is it vise versa...???
Old May 17, 2003 | 12:25 PM
Directfreak's Avatar
I am a Jeeper Now.
Read here.
Old May 17, 2003 | 01:45 PM
MRGSL-SE's Avatar
thanks directfreak... custom headers looks like the only way to make that fit somehow... or a really HUGE SPACER and you'll still probably won't clear properly
Old May 17, 2003 | 03:54 PM
I am a Jeeper Now.
Sure they will.
Scroll down, and read on.
Old May 17, 2003 | 10:34 PM
MRGSL-SE's Avatar
Did you weld that yourself???
I just won an auction for a TURBO 2 turbocharger and I guess this project is on its way... what does side play and end play mean??? the item said NO END PLAY but little or no side play...???
Is it a good idea to turbo up a motor with 167k??? original miles no rebuild... rebuild seems so expensive for my pocket right now(even with the rebuild kits)....
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
