if compression is ok, can you still need a rebiuld?
Old Aug 31, 2001 | 11:47 AM
technonovice's Avatar
Jinx
I'm down in power by 10-15%. I am going to get a compression test.
Are there other issues that require a rebuild even if the compression checks out?
I have no visual emissions other than the white stuff at start up. It dissapates beyond 6-8 inches so I think it is just water vapor.
Old Aug 31, 2001 | 04:45 PM
Bad water seals???
Old Aug 31, 2001 | 06:13 PM
Jinx
Originally posted by broke3rdgen
Bad water seals???
I have no idea if that would affect the compression or not.
Old Sep 2, 2001 | 08:33 AM
Jinx
What do I have to do to get an answer...bribe someone with ****?
Old Sep 3, 2001 | 08:20 AM
black99's Avatar
Lurking..................
Yes there are other things that require you to do a rebuild besides bad compression. Like warped housings and bad water seals... But I think if you had either of those it would spew coolant after you parked it and let it sit. Your motor sounds alright to me from what you said, that is if the compression test checks out. But don't rely on me for your sole answer, you might want to check with some place that specializes in 3rd gen rx7's too...
Old Sep 7, 2001 | 01:14 AM
Nathan Kwok's Avatar
If you have good compression, it would be hard for there to be a problem with your motor. There are lots of people who have low compression and their cars still run great, but I've never heard of a person with good compression and a blown motor. I suppose mildly blown O-rings can still give good compression, but not for long. A warped housing (or warped anything) would definitely kill your compression. If you check out on the compression and still have a power problem, it could be a ton of things. First check the boost, if that checks out, you could be misfiring, have a clogged air filter (or clogged cat, or clogged anything for that matter), broken thermosensor, or other things I haven't thought of.
turbodreamz22
28
Nov 10, 2023 11:08 AM
Andrew7dg
Aug 6, 2017 01:41 PM
93FD510
Oct 1, 2015 02:00 PM
