Sponsored by: CARiD
On Swap do i have to rebuild
Old Apr 30, 2003 | 09:57 AM
Sojin's Avatar
Question On Swap do i have to rebuild
im doing a N/A to a Turbo ll in my 87 rx-7 and i have the motor but no money to do a rebuild? Help me
Old Apr 30, 2003 | 10:35 AM
Cosmo Donk's Avatar
Queer
Does it NEED a rebuild? If it does, then there is nothing we can do because most of us have no money either
Old Apr 30, 2003 | 10:56 AM
Sojin's Avatar
im asking dose it because i want to have fun with may car and i just blow a seal on my old motor
Old Apr 30, 2003 | 12:05 PM
Cosmo Donk's Avatar
Queer
Huh?
If you are asking us if it needs a rebuild you are asking the wrong question because there is no way we can tell you that.
Old Apr 30, 2003 | 05:35 PM
Sojin's Avatar
CAN YOU TELL ME HOW I MITE TELL IF I NEED TO BE REBUILD.
Old Apr 30, 2003 | 07:47 PM
jgrts20's Avatar
Who are you?
well for starters, does it smoke(black) and does it run like sh*t? then u go from there!! :p
otherwise u can buy a bolt on turbo and replace the exhaust for a turbo!! PEACE man and good luck!!
Old May 1, 2003 | 10:03 AM
Sojin's Avatar
THE THING IS THAT THE MOTOR IS OUT AND ITS A j-SPEC WITH ONLY 20K
Old May 1, 2003 | 11:25 AM
Cosmo Donk's Avatar
Queer
Do a compression check. If the motor is not in the car and cannot be tested with a compression checker there is no way to correctly test it.
You can get an idea by turning the engine by hand with the spark plugs out and listen to the compression pulses. You should hear 3 solid swooshes out each rotor.
SCinfidel
Sep 8, 2015 05:36 PM
rotor_veux
Sep 3, 2015 07:10 PM
