Question re: Brake Booster
Old Feb 14, 2003 | 12:03 PM
TTREX's Avatar
I just got a new brake booster from the local auto parts and the back plate is turned 45 degrees from the OEM. The mounting studs do not match up with the holes in the firewall, and the master cylinder would be mounted on its side.
Can the back plate be turned the 45 deg? How difficult is it to take off the plate and reinstall?
I'm hesitant to reorder as the parts store and I have had a run of bad luck finding correct fitting parts.
Also, I have an 85 GS but parts of the car seem to be 86 or beyond and others - we can't identify at all. Has this been a problem wit 85's?
Thanks
Old Feb 14, 2003 | 12:05 PM
MikeLMR's Avatar
'Last Minute' Rallying
If its not the correct part take it back ... do not screw around with brakes
Old Feb 14, 2003 | 12:07 PM
damon's Avatar
from memory there are 4 different boosters for the fb . i wold take it back and tell them its the wrong one
Old Feb 14, 2003 | 01:28 PM
specRX7_22's Avatar
the race car is an 83 and it uses an 85 booster. works fine
Old Feb 14, 2003 | 02:43 PM
TTREX's Avatar
Yeah, I don't doubt it can work, because of the RX parts versatility. The problem is that the M/C will be laying on its side if I install it according to its bolt pattern.
Guess I'll take it back and wait for the next one.
Thanks for the advice
Old Feb 14, 2003 | 03:37 PM
Keaponlaffen's Avatar
yeah, if it was anything else I'd suggest trying something else with it, but brakes are NOT something to screw around with, as mentioned before.... you can go without power, but if you can't stop, you've got problems.... ever try turning the key off on your car and pumping the brakes a couple times while going down a steep hill, and then trying to stop? That's hard... haha... yeah. Take it back, try another one. Tell them the problem, maybe they know something about it.
Old Feb 14, 2003 | 06:47 PM
Redwood's Avatar
Find Racing
Doubt that, knowing parts stores.
Anyway, as everyone else said, get a different one.
Old Feb 15, 2003 | 01:45 AM
Meh, maybe your parts stores are different down there
the Lordco and NAPA here both have knowledgable staff, who actually know what they're talking about. I go to Lordco mostly, as Ross there has owned 4 RX-7s in the past, and know pretty much every part number by heart.
diabolical1
30
Jan 30, 2016 05:50 AM
Snoopy FD
Dec 8, 2015 01:45 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 13, 2015 11:19 AM
