exhaust piping size
Old Feb 13, 2003 | 03:20 AM
xlversatilelx's Avatar
exhaust piping size
what is the best size for piping?? i was thinking 2 in. or 2 1/4 what is best?? and what size inner diameter muffer should i get 60mm , 80mm, or any other sizes?? thanks for the help
Old Feb 13, 2003 | 04:35 AM
PaulFitzwarryne's Avatar
Apprentice Guru
The ideal size is 2 1/8 inch for a 12a, but that is difficult to obtain so 2 1/4 is a good compromise. Its best to get it made up in stainless due to the high temperatures with a rotary exhast.
Old Feb 13, 2003 | 05:53 AM
buzz's Avatar
Australian Idle
I have 1/8" thick (3mm) wall main pipes at around 2 3/8 od - I am getting a lot of pipe noise, as in metallic ringing, so I really think its too big. they messed the numbers around, I was really after 2 1/4 od, 1/8wall (thus 2" id). This *should* have been fine on my 13b bp. Mine isn't stainless, but a shiite load of single mandrel welded together.
AS for muffler... baseline is dont get anything smaller than your pipe!
Old Feb 13, 2003 | 10:53 AM
I use 2 1/4, works great with a low restrictive muffler and header. But there is no point of increasing your pipe size if you dont have a header and you have a cat.
I think I paid 25 bucks for my pipe, and like 50 bucks for labor.
Try to find an import shop to do this, no normal exhaust shop will touch your car if you dont have a cat.
Good Luck!
Old Feb 13, 2003 | 11:52 AM
oh okay cool thanks does any one know were i can get the 2 1/4 piping i was thinking racing beat but they only gor 2 in. i wanted it from racing beat because their pipes are 1/8 in thick. know any where else i can get 1/8 in thick but 2 1/4. okay thanks a lot
Old Feb 13, 2003 | 03:47 PM
Well, if you lived in MN, id say go to rx7 heaven!
Old Feb 13, 2003 | 06:22 PM
WackyRotary's Avatar
standard combustion
I'd never use Rx-7 heaven/hell except for getting used parts. Overpriced and questionable ability of their "mechanic". Just my opinion, but this opinion is shared by many here.
Old Feb 13, 2003 | 07:26 PM
Tony the owner, is the original owner of my car. He seems like a very nice guy and easy to work with. His mechanic is pretty coll also, ive talked to him a few times. He seems to know his stuff.
Unless he is just working with me becasue it used to be his car?
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
