which of these mufflers would you use for a presilencer.
Old Jan 7, 2003 | 11:52 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
This is for a turbo application, full 3 inch with a N1 style at the back.
Which of these mufflers would you use for a presilencer.
http://store.summitracing.com/partdetail.asp?part=32914
http://store.summitracing.com/partdetail.asp?part=34809
http://store.summitracing.com/partdetail.asp?part=2156
what do you think, I leaning toward the summit one.
its cheap and it wont affect my ground clearance
but it says it has a louvered core, im not sure what that means.
Old Jan 7, 2003 | 01:22 PM
ioTus's Avatar
'84 5-letter
Well, I have been told that straight through mufflers wont do **** for your exhaust. If y ou seriously watn to make it quieter, you must use presilncers. the problem with them is they are much more restrictive, so they wont be as effective, but t hey will be much quieter.
THat is NOT from personal experience tho, thats just what ppl told me. So that said, i'd prolly go for the summit one as well, whatever's cheapest.
Old Jan 7, 2003 | 08:04 PM
yeh, i just ordered one. Once I get it and I can see what this "louvered" core looks like and how much space I have on the bottom of the car, i might order a second.
Old Jan 7, 2003 | 09:43 PM
680RWHP12A's Avatar
i would buy tis one! 3"
Old Jan 8, 2003 | 01:30 AM
V8kilr's Avatar
I'd go with a racing beat presilencer, its not that much more then the summit
Old Jan 8, 2003 | 08:43 AM
stevehilde's Avatar
82SR: Check your PMs.
Old Jan 8, 2003 | 04:27 PM
okay, I just found out that the glasspack style muffler has a 2.5 in core, not 3 inch.
damn, that would have worked perfectly, ill see how bad it is when I get it, maybe it will still work.
Old Jan 8, 2003 | 04:49 PM
nimrodTT's Avatar
all aboard!
Even on a turbo car, the fiberglass packing won't last long. But you'll get some decent mufflage from any of those if you repack them with stainless-steel wool.
The louvered core has little cup-like shapes pointing into the flow of the exhaust to scoop it up and divert it away from the tube and into the body of the muffler.
Old Jan 9, 2003 | 06:06 AM
Rx7carl's Avatar
Airflow is my life
What do you guys think of this as a presilencer? For an N/A 12A, long primary type system.
http://www.jegs.com/cgi-bin/ncommerc...57&prmenbr=361
Old Jan 9, 2003 | 10:59 AM
mperformance's Avatar
RX7carl you have to make sure it is not fiberglassed packed but stainless steel wool or similar material...it doesn't specify either
Old Jan 9, 2003 | 11:03 AM
Rx7carl's Avatar
Airflow is my life
It's probably fglass, but even after it burns out in 10 minutes, itll still do some quieting.
Old Jan 9, 2003 | 11:06 AM
in that case it looks good
Old Jan 9, 2003 | 03:56 PM
Hyper4mance2k's Avatar
The Shadetree Project
its only 1-3/4" diamater inside too small if you ask me
and the only presilencer i say is the dynomax bullet!! small and steel packed and only like $60
Old Jan 9, 2003 | 05:18 PM
Rx7carl's Avatar
Airflow is my life
Well the mfg webpage says its a 2" core, so I dunno . Yea but a dynomax bullet doesnt come in 2" in/out.
Old Jan 9, 2003 | 09:41 PM
Kill No Cone's Avatar
The $60 Dynamax mufflers are packet with "revolving fiberglass," It is the $130 stainless Dynamax muffles that are packet with steel.
Old Jan 9, 2003 | 10:22 PM
nimrodTT's Avatar
all aboard!
LOL, spinning fiberglass! (it's roving) And the $110 ss dynomax that was posted has the fiberglass packing too.
Old Jan 9, 2003 | 11:54 PM
Mazda Comp has a $130 Stainless Dynamax racing muffler that is packed with stainless.
Old Jan 10, 2003 | 01:18 AM
luiml73's Avatar
Rotary Powered Boobies
stick with the RB. You will end up saving money in the long run.
Old Jan 10, 2003 | 11:18 AM
the ultraflow round is packed with a combination ceramic and fiberglass, it is advertised to handle 1500F
if I place the muffler near the rear axle, on a 3 inch system, wouldnt that be fine. It cant be that hot that far back.
Old Jan 10, 2003 | 02:40 PM
oh yea that far back its in the 3 didget range
Old Jan 10, 2003 | 03:28 PM
1st7heaven's Avatar
The only presilencers and muffs. I have found to work over a long period is the RB products!! I dont drive on the street anymore but on the race car the only thing that lasts is the Lava packed muffs.....$300-$500. I use the DynoMax stainless muff. 3" in and 3" out. I have to replace it once a year......racing. You also have to remember, if your car bellows flames this will burn it out very fast!!!
Old Jan 10, 2003 | 04:04 PM
oh, im hoping it will blow out flames.
Old Jan 10, 2003 | 04:32 PM
Rx7carl's Avatar
Airflow is my life
1st7, why not pack your own lava mufflers?
Old Jan 10, 2003 | 10:26 PM
diabolical1's Avatar
i think it's worth giving the 2nd one a shot. remember that the turbo itself has some muffling effects on the exhaust just by being there, so you won't be starting with the same raspy, loud-*** VOLUME as an N/A engine would have. the only thing is it might be too long depending on where you plan to use it ... and i'd recommend aiming for use closer to the engine for any presilencer.
i'd suspect you may have clearance issues with the 1st one (speed bumps, etc.)
the Borla unit is shorter, and looks like it might be a good second choice ... it's just not clear as to what packing it has.
hope this helps.
Shainiac
Jul 17, 2019 02:20 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
jeremyferguson4444
Sep 19, 2015 01:27 PM
