1st Gen Turbo Conversion
Old Dec 12, 2002 | 05:01 PM
LTProject's Avatar
Question 1st Gen Turbo Conversion
I'm doing a 1st gen conversion with a new Hayes turbo motor. I've bought the engine and the turbo so far. I have alot of questions though, will start with my turbo weights 51lbs, what manifold will support this thing? Next question is my turbo is a Garret TV73, its very large,i'm wondering if this is going to fit in the engine compartment? You guys on the forum have been alot of help so far, my local shops cant even spell rotary, so its up to us to suprise the hell out of them. thanks mike
Old Dec 12, 2002 | 06:35 PM
setzep's Avatar
Just a hunch.. If your turbo weighs 51 pounds it might be a little too big. Wait, what rotary engine do you have?
Old Dec 12, 2002 | 07:17 PM
LTProject's Avatar
My engine is a 89T with a big street port and 3mm seals,ceramic coated rotors. I dont have all the paperwork yet so thats as much as i know. There are some specs on the turbo, it has a .75 compressor and a 1.08 turbine. This is going to make you laugh, the turbo is off of a detroit diesel, but i called turboperformance and talked to one of the guys down there and he said itll work fine. I gave him the part number and he said it should be good for 800hp! I really didnt want to go that dam high, but what the hell. My car is at the rollcage shop so i dont even know if itll fit.
Old Dec 12, 2002 | 10:08 PM
Directfreak's Avatar
I am a Jeeper Now.
I have to agree with Setzep, 51 lbs is very heavy. Is the Turbo designed for a regular T-04 flange? or Truck sized flanges? Either way sounds like you need a reinforced exhaust manifold or cast iron top hold it up without cracking something.
Either way, If the Turbo is oversized, it will lag significantly. But I guess if you're getting a roll cage it's for some kind track only.
The engine you're getting sounds good, just build your turbo system around your HP and usage goals. (ie track, street, drag racing, etc.)
Good Luck, and Here's a Good Thread on Turbo 1st Gen converstions , although there appears to a few pages missing right now.
Old Dec 13, 2002 | 07:46 AM
LTProject's Avatar
the turbo has a standard T4 flange, i emailed the guy i bought it from and he said what you said, i need a manifold custom made. The reason im putting a cage in it is ive heard of alot of 1st gen turbos going very fast, and id like not to get kicked off the strip or die. thanks for the link ill check it out.
Old Dec 13, 2002 | 08:43 AM
banzaitoyota's Avatar
What Subscription?
Sounds interesting
Old Dec 13, 2002 | 10:55 AM
rotarygod's Avatar
Rotors still spinning
With a turbo that big is it going to look like you have a turbo'd rotary or a rotary'd turbo under your hood!?
Old Dec 13, 2002 | 12:07 PM
LTProject's Avatar
do you guys know of anyone making quality manifolds for turbos this size? Im in stlouis so maybe in the nearby states.
Old Dec 13, 2002 | 06:55 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Good luck man, no one close to us I dont think. Im about 2 1/2 hours from you, and I dont know anyone that willl make custom manifolds
Old Dec 13, 2002 | 07:59 PM
LTProject's Avatar
well thanks anyway, ill figure something out. im going to a local turbo builder tomorrow to get the maping on this thing and have him put it on a diet. as it sits now it takes a 5inch down pipe, looks like the passenger compartment has now been taken. ill be putting up some pics after the cage is in for you guys, im gonna have some fun with this car.
Old Dec 14, 2002 | 11:42 PM
riffraff's Avatar
smog nazi destroyer
5 in downpipe? damn that is huge.
Old Dec 15, 2002 | 12:18 AM
I am a Jeeper Now.
Contact information included in the link.
Old Dec 15, 2002 | 12:22 AM
crispeed's Avatar
'Tuna'
Go too sleep!
You need to be at the track early Tommorow and don't forget to charge the battery for the cam!
crispeed
Old Dec 15, 2002 | 08:29 AM
LTProject's Avatar
nice pics of your manifold, well ive got one coming its supposed to be made out of stainless. So far ive spent about $4900 in about 4 days. I just found that parallel fuel diagram on fc3s, i love the internet. thanks guys
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Marty RE
Aug 13, 2015 11:19 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
