T51r Kai Bb
Old Dec 3, 2002 | 02:52 AM
Chronos's Avatar
Question T51r Kai Bb
Anyone have any stats on the new T51R (t52r?) KAI BB turbo...someone on this thread mentioned it was 1000rpm quicker spool which would be 3,000rpm which would be awesome, but someone else I was talking to who runs a T51R KAI nonBB said they only spool 500rpm quicker, which I'm not sure if that would warrant all the extra money...anyone know how the responce is as opposed to say a HKS T04R or even a GT35/40??? Joe (T51quicksilver), I heard you have some experience with these units...any comments?
Thx!
Old Dec 3, 2002 | 03:55 PM
94SR2's Avatar
HKS lists on it's spec sheet that the KAI BB spools only 11% quicker than the NON-BB KAI. And yes that turbo is almost 2x as much for only 400-500rpm(depending on full spool prior) quicker spoolup. Not worth it in my opinion depending on what you're doing with the car.
-ed
Old Dec 3, 2002 | 06:47 PM
Resource's Avatar
It only spools 400-500 quicker.My t51RKAI spools pretty damn fast if you ask me
Old Dec 3, 2002 | 09:27 PM
Carl Byck's Avatar
Mad Man
Resource, What rpm do you see 15psi? What hp at that psi?, When do you see full boost? What is your max boost? What HP at that boost? I am assuming race gas above say 16psi, is your motor doweled? If so how many dowels? Anybody running over 18 psi un- doweled? how much boost, how long? anybody running a PT67? If you are , you know what I am talking about, PM me, thanks, Carl
Old Dec 4, 2002 | 04:17 AM
Chronos's Avatar
don't PM, post in the thread so I can see too
Old Dec 4, 2002 | 07:14 AM
sokudo's Avatar
i get 1.4 boost at about 3500 on full bridge port motor. dynoed at 650 hp with bb kai. it rules!!!!
twins are for winers!!!
Old Dec 4, 2002 | 08:03 AM
forcefed7's Avatar
SPL@34psi no dowels...
Old Dec 4, 2002 | 08:24 AM
Resource's Avatar
Good grief that's alot of questions.
I see 13 psi @4700
No dyno yet
Not doweled
Old Dec 4, 2002 | 08:25 AM
Resource's Avatar
Can you post pictures of your turbo?
Old Dec 4, 2002 | 08:31 AM
forcefed7's Avatar
I have some at home that I can post tonight.
Old Dec 4, 2002 | 09:09 AM
Resource's Avatar
Do you mind?I'd really like to compare your HKS T51R SPL to my T51R KAI.
Thanks a bunch!
Old Dec 4, 2002 | 11:04 AM
nocab72's Avatar
03 Cobra Killer
I asked Rob @ Pineapple if I needed dowels with my 600rwhp goal. He laughed and said no.
K
Old Dec 4, 2002 | 12:44 PM
Resource's Avatar
K
That's what I've heard as well.
Old Dec 4, 2002 | 08:08 PM
Astro's Avatar
So exactly when are dowels neccesary?
Is it complete overkill to do it if 500rwhp was the goal, or can it be seen as some extra insurance?
Old Dec 4, 2002 | 08:15 PM
forcefed7's Avatar
Here's a few pictures of the SPL.
-Ray
Thanks a bunch!
Old Dec 4, 2002 | 08:17 PM
forcefed7's Avatar
another...
Old Dec 4, 2002 | 08:21 PM
forcefed7's Avatar
Pic of the KAI.
Old Dec 4, 2002 | 08:33 PM
Bridgeported's Avatar
650 rwhp at 20 psi (1.4 bar) is pretty good. I've seen similar set-ups making that power at 25-28 psi.
Do you have a dyno graph?
Old Dec 4, 2002 | 08:36 PM
i could see dowels as being very useful on high torque high hp cars. i mean our motors are just plates stacked one on top of the other. on top of that, each succesive plate is made of a different material, with different rates of expansion and different resistances to torsional forces. i'd think any additional reinforcement is good as long as you can afford it. this would be especially true for motors that are expected to last a long time.
Old Dec 4, 2002 | 09:41 PM
Resource's Avatar
Hmm,the front side of the 2 turbos look the same.Is the only diff is the compressor?
Old Dec 4, 2002 | 09:57 PM
forcefed7's Avatar
The KAI has a 70mm compressor wheel and the SPL has a 76mm, everything else is the same between the two. Everyone says the SPL has a lot more lag the KAI, that has not been my experience though...
Old Dec 5, 2002 | 12:46 AM
Chronos's Avatar
HKS T51R KAI -
COMPRESSOR:
-Wheel- 56 Trim - 70.3 Inducer / 94.0 Major
-Housing- 100 Inlet / 80 Outlet
TURBINE:
-Wheel- 76 Trim - 82.0 Major / 71.4 Exducer
-Housing- V-Band inlet / V-Band 115.5 mm outlet - 1.00 A/R
HKS T51R SPL -
COMPRESSOR:
-Wheel- 56 Trim - 76.5 Inducer/ 102.2 Major
TURBINE:
Old Dec 5, 2002 | 12:47 AM
Chronos's Avatar
much bigger compressor as you can see
20B Junkie
20B Forum
Aug 11, 2003 07:24 PM
wentpearshaped
Sep 12, 2001 11:34 AM
