how much boost until boom
Old Oct 21, 2002 | 10:46 AM
how much boost can a 13b handle?
Old Oct 21, 2002 | 11:08 AM
Mahjik's Avatar
Mr. Links
Re: how much boost until boom
Stock turbos? Stock injectors, fuel pump?
Are you talking about just the stock engine with stock seals?
There are people using 13b's with single turbos pushing some serious PSI. Search for posts by "ErnieT".
Old Oct 21, 2002 | 11:16 AM
OptusX4's Avatar
A lot. Mainly they have a tendency to go boom on high boost cause AFR's lean out. If you keep everything in check, with proper fuel/timing, you can put huge turbos on them.
Old Oct 21, 2002 | 11:19 AM
i just want to know what the most boost youv ever heard some one run with out blowing up, but i wanna hear about rotors blowing hoods off and things like that
Old Oct 21, 2002 | 11:26 AM
Rotary Master
I have no idea how much pressure in and of itself the seals can take.
Old Oct 21, 2002 | 11:29 AM
hmmmmmmmmm sounds like a job for some one with deep pokets, maybe twin blitz turbos
Old Oct 21, 2002 | 12:09 PM
RotaryKnight's Avatar
It's mostly the tuning that counts. I daily drove mine with T04S, 1300cc secondaries...other stuff.... stock motor at 1 bar.
Some people can do more. Also you don't need that much boost to make a FD fast. A 400 rwhp FD can keep up with other cars pushing 550-600.
Chris
Old Oct 21, 2002 | 12:21 PM
the_glass_man's Avatar
Will u do me a kindness?
I've heard of close to 40 psi on stock 2 mm apex seals.
Supposedly the start to "float" after 30 psi.
You have to remember all the pressure that the rest of the seals (coolant, etc..) must also stand up to the abuse.
If you really want to push that much boost, you will want to run lower compression rotors from the early turbo RX-7's. They are less prone to dent, under extreme loads.
Old Oct 21, 2002 | 12:49 PM
teamstealth's Avatar
Ozone Depleter
40psi?! Thats insane!! How much HP do u think that motor put out?
Old Oct 21, 2002 | 01:14 PM
twiztedjeckel's Avatar
buy an mbc, go out and ram around for alittle while and find out.
Old Oct 21, 2002 | 01:46 PM
reza's Avatar
hmm 40psi...maybe the rx-7 can make a nice leaf blower...
reza
Bauer778
Nov 4, 2015 04:42 PM
Devon300zx
Sep 17, 2015 03:50 PM
REX7&Z32TT
Sep 9, 2015 05:16 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
