Flooding
Old Oct 18, 2002 | 09:41 AM
RXTHIS's Avatar
Flooding
How can i make it stop flooding? EVERY DAY IT FLOODS AND and its pissing me off. and its embarassing as hell. is there anything i can do to stop it i have 170000kms....pls help
Old Oct 18, 2002 | 10:43 AM
SureShot's Avatar
Seduced by the DARK SIDE
Get the fuel injectors cleaned and install a fuel pump cut switch. Try to avoid starting & shutting it off cold (warm it up some before shutting off).
Old Oct 18, 2002 | 10:47 AM
Roy James's Avatar
My cars louder than yours
Try this, when you go to start the car, put the foot ALL THE WAY to the floor. RX7s have a fuel cut switch built in when the pedal is all the way to the floor. I am positive its on S5 cars, and hear its on S4 cars (and it works for my S4 car, so i presume its fine)
Old Oct 18, 2002 | 11:12 AM
StarionX's Avatar
Re: Flooding
This will show you how to make a fuel cut switch.
https://www.rx7club.com/forum/showth...looding+switch
Old Oct 18, 2002 | 11:35 AM
Kspurr's Avatar
Sometimes I miss my RX-7s
Switches are ghetto, try having the injectors and then if that doesn't fix it yank the fuel pump and rip the little plastic valve that looks like a little basket out of the nipple with needle nose pliers. The car won't hold fuel pressure when its off and flood. It;ll take about one unnoticeable second for the car to build pressure when you start it, but it'll probably never flood again.
Or you can use a ghetto rigged switch and turn the car over, flip the switch again and start the car with a wonderful plume of smoke (unburnt gas) . The chicks really dig that.
Old Oct 18, 2002 | 01:58 PM
RXTHIS's Avatar
instead of having a fuel fuse i have a switch...that i can flip and it will enable me to do the unflooding thing but its a pain in the ***.....
Old Oct 18, 2002 | 02:04 PM
Spraintz's Avatar
Edmond Dantes
Roy_James is correct.
when starting if it floods press pedal to the flor and hold it(DO NOT pump) and it will stop the injectors until until it fires.
I have some really high miles and I flood every now and then and this works perfect for me.
Good luck
Old Oct 18, 2002 | 02:14 PM
RXTHIS's Avatar
yeah it was so weird too. i was just driving now and it died dead...no bang or anything...the starter wont move i juet get a clicking noise....i hate it
Old Oct 18, 2002 | 02:19 PM
Spraintz's Avatar
Edmond Dantes
clicking noise. hmmmm
you can check the starter but its prolly a bad ground.
that happened to me on my old 87 base and a replacement starter did the same thing.
Good luck
Old Oct 18, 2002 | 02:22 PM
RXTHIS's Avatar
would it just die like that though...i was slowly starting off..it felt like i stalled it cause i jerked hard
tidanb0utch
11
Oct 7, 2015 07:36 AM
FbFuninthesun
Oct 6, 2015 08:03 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Monsterbox
Sep 11, 2015 03:29 PM
