Grinding gears while downshifting
Old Oct 2, 2002 | 04:30 PM
808FC's Avatar
Question Grinding gears while downshifting
when im driving my 2nd and 3rd gear almost always grind while im downshifting but never while im upshifting. when i downshift i usually rev to match the rpms. is this a synchro prob of do you think if i just put in the synth trans fluid itll be enough.
Old Oct 2, 2002 | 04:37 PM
I wish I was driving!
Synthetic is about your best bet to try. Does double clutching help (doubtful if you're rev-matching...)? What about upon a clutchless downshift?
Old Oct 2, 2002 | 04:45 PM
Pinfield357's Avatar
puting in some redline fluid may help it helped me!!!
Old Oct 2, 2002 | 05:10 PM
powerlover's Avatar
you could just try not downshifting. brakes are alot cheaper than a motor, tranny, or clutch.
Old Oct 2, 2002 | 05:23 PM
Please tell me you're joking.
Tell me how to accelerate on the freeway by using the brakes....
I downshift from fifth to third. For some reason, braking never crossed my mind.
Old Oct 2, 2002 | 07:13 PM
powerlover's Avatar
are you using your clutch at all or are you trying to powershift it?
Old Oct 2, 2002 | 07:34 PM
Turbonut's Avatar
Just curious-It won't grind if you downshift at a lower rpm, correct?
If this is the case, you can try synthetic, but the syncros are probably shot. Just replaced all syncros in my '89TII, would only grind if downshifting at higher than normal RPM's. Half the groves on the syncros were worn off.
MILOS7
Oct 9, 2015 02:19 AM
musker
Oct 1, 2015 05:58 PM
