gas smells rich, is this normal??
Old Sep 19, 2002 | 09:56 PM
DSM
Unhappy gas smells rich, is this normal??
when i crank my '90 FC you can smell the gas, and it smells very rich. is this normal?? what should i do if it isnt??
Old Sep 19, 2002 | 10:57 PM
autocrash's Avatar
Now with more 1st Gen!
so.. uhmm... is there suddenly a difference between the smell of rich gas and lean gas?
(sorry, had to... the voices in my head made me do it...)
Old Sep 19, 2002 | 11:01 PM
rx-7fc's Avatar
bump
Old Sep 19, 2002 | 11:02 PM
autocrash's Avatar
uhmm... did it really need to be bumped? it was right at the top... lol....
Old Sep 19, 2002 | 11:03 PM
RestoTII's Avatar
first thing I would check is spark. That might be caused by a lack of spark (plugs, wires, coil packs), however, that would mean that there's also probably a leak underhood to let the fumes out for you to smell. There's also the cold start/hot start deal that might be running it too rich and allowing some extra gas to seep out. Have you modified any of the emissions or starting equipment? If so, that would be the first place to look, and if not, then I'd check for spark (use a voltmeter to test each step and make sure there's voltage at the end)
Old Sep 19, 2002 | 11:06 PM
autocrash's Avatar
Yeah.. uhmm... does the car START? or are you just cranking it? wtf is the situation?
Old Sep 20, 2002 | 01:00 AM
FC Drifter's Avatar
Damaged Little F*cker
if youre talking about being able to smell fuel in your exhaust, thats pretty much the norm.....for a modded FC. if you dont have exhaust mods(no cats) then id check something. the fuel smell on a stock car shouldnt be that strong.
Old Sep 20, 2002 | 01:29 AM
Rotorific's Avatar
I dont know a damn thing
I smell fuel all the time and but i have a racepipe and single exhaust i dont care
Old Sep 20, 2002 | 10:20 AM
rx7_turbo2's Avatar
Professor D.P
If you smell raw unburnt fuel all the time you have a leak somewhere, your first place to check is the pulsation dampner.
If you smell a "rich" fuel smell that is to say raw fuel that has made it through the engine uncombusted then there could be any number of problems.
In order for anyone to help you your going to have to specify what exatly the problem is.
Old Sep 20, 2002 | 11:20 AM
I have an 87 na and the exhaust always smells of gas.
I believe no cats is the cause. Some guy on the forum was using an msd box to boost the spark and he said the fumes went away. without the cats the extra fuel just passes on through and out the tailpipes.
Old Sep 20, 2002 | 01:53 PM
darkwaveboi's Avatar
Need donor car in Fairfax
mine blows up and burns my bumper
Old Sep 20, 2002 | 02:37 PM
mines just smells like a go cart lmao
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
jeremyferguson4444
Sep 19, 2015 01:27 PM
Monsterbox
Sep 11, 2015 03:29 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
