cats
Old Sep 14, 2002 | 08:57 PM
TKE's Avatar
TKE
cats
I'm looking at an '87 gxl I want to buy. The owner says it's completely stock and the exhaust looks stock, but there is only one cat. I thought all NA's came with three cats? Did '87 gxl's only come with one?
Old Sep 14, 2002 | 08:59 PM
I wish I was driving!
Re: cats
Nope, its not stock. They came with one cat, and two precats. Precats only function for cold emissions, though.
Old Sep 15, 2002 | 01:05 AM
Digi7ech's Avatar
I break Diff mounts
What do You mean by Cold Emissions? When the car is Cold? or something else.
If so then I should toss my precats since I'm in Arizona.
Old Sep 15, 2002 | 01:08 AM
jacobcartmill's Avatar
just dont care.
**** cats.
Old Sep 15, 2002 | 01:09 AM
AreExSeven's Avatar
Huh?
Originally posted by jacobcartmill
**** cats.
Join Greg and Rpeck and try to rid the world of these vile creatures...
Oh, you mean catylists. NM Then
Old Sep 15, 2002 | 02:00 AM
bingoboy's Avatar
Lava Surfer
cold emissions? oh and if i got a bonez dual high flow cat setup what would i do about them precat things? im trying to stay california legal and all...at least for a couple years anyway :P
Old Sep 15, 2002 | 03:46 AM
NRA T2's Avatar
if you run cats you ain't no dogg
Old Sep 15, 2002 | 11:45 AM
jsotelo's Avatar
I'm curious about this as well. Could I replace all three cats with a single C.A.R.B. certified high flow and be cool under Cali big brother emissions?
Old Sep 15, 2002 | 12:09 PM
rx-7fc's Avatar
will a bonez dual high flow cat setup pass emissions in cail because i am thinking of buying it
Old Sep 15, 2002 | 09:12 PM
The two precats operate only under start-up, to remove cold-engine emissions. They do not function much during operating temp, and removing them will not affect normal running emissions. Since there is no way to test cold emissions, there is no worry.
You will pass emissions with a bonez set-up, however, keep in mind that you may fail visual if you do not have all three cats in place.
Old Sep 15, 2002 | 09:56 PM
dre_2ooo's Avatar
**** cats.
embrace prison
Old Sep 16, 2002 | 02:11 AM
bingoboy's Avatar
Lava Surfer
so if i want a higher performance exhaust, but i still have to worry about passing emmissions, whats my best option?
Old Sep 18, 2002 | 12:23 AM
rx-7fc's Avatar
bump
Old Sep 18, 2002 | 12:29 AM
Icemark's Avatar
This:
http://www.rx7.com/cgi-local/2catalo...cat=4&part=100
or this:
http://www.rx7.com/cgi-local/2catalo...cat=4&part=110
Old Sep 18, 2002 | 12:44 AM
rx-7fc's Avatar
will is pass in ca too
Old Sep 18, 2002 | 01:00 AM
Icemark's Avatar
Both will pass CA emissons, however if you go someplace that really knows RX-7s and the FC in particular you may not pass the visual on a series 4 NA car. But to the average smog shop, you will not have any problems passing.
The dual cat is also CARB legal in CA on series 5 cars.
Old Sep 18, 2002 | 01:03 AM
bingoboy's Avatar
Lava Surfer
why is it legal on s5 and not s4? i have an s5 but im curious none the less. and do you live in CA icemark? if so what do you run cats/muffler/piping.
and are there laws that govern muffler stuff for CA? ive been here 3 years but havent done any car modifications or actually had a car here till recently.
thanks
Old Sep 18, 2002 | 01:12 AM
Icemark's Avatar
thanks
Because the series 4 NA cars have 3 cats, while the series 5 have only 2.
Yes I live in CA. I use a custom down pipe and Bonz turbo cat and the stock cat back (because I haven't been working and don't have the funds saved up for a new exhaust yet). I will probably go with either the RB or Corksport, eventually. Since I have a 'vert noise is a bigger issue than on a Coupe.
Old Sep 18, 2002 | 02:18 AM
bingoboy's Avatar
Lava Surfer
do you like the bonez cat and do you think it made much difference?
Old Sep 18, 2002 | 08:01 AM
silverrotor's Avatar
I'm actually going In an hour to swap out my s.s hi-flow cat with a s.s straight pipe. Shame on me.
Old Sep 18, 2002 | 10:22 AM
Icemark's Avatar
It hard to tell, since it went in when I put the 13BT in. I guess what it came down too was that I didn't trust the stock NA cat and the HI-flow Turbo model replacement allowed me to meet emissons and was cheaper than a new OEM or OEM knock off cat. See, I have the double wammy of having to meet NA emissons with a turbo car now.
And as many on this board know I am a firm (and often outspoken) believer in meeting the emisson requirements in CA (or the area you are in) while still having decent HP. Responsible performance I call it, so unlike Silverrotor and others, I am against ripping out all the cats or other emisson controls on a street car so that my car stinks and pollutes the area for a couple of extra HP. That meager extra little bit of performace is just not worth it in my eyes. If you need to take polluting short cuts on a street car to win or whatever, you got the worng car IHMO. Buy something that has the HP you need without ******* up the emissons system.
Old Sep 18, 2002 | 11:25 PM
rx-7fc's Avatar
can you use the dual cat on a s4 and pass in ca or it is only CARB legal on a s5
Old Sep 18, 2002 | 11:39 PM
Icemark's Avatar
as I posted above:
Old Sep 19, 2002 | 10:07 AM
**** cats again
Old Sep 19, 2002 | 10:13 AM
autocrash's Avatar
Now with more 1st Gen!
**** cats.
Uhmm... isn't that cruelty to animals?
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
