View Poll Results: How high have you boosted?
0-5
22
14.77%
6-10
35
23.49%
11-17
65
43.62%
18+
27
18.12%
Voters: 149. You may not vote on this poll
Old Sep 5, 2002 | 06:48 PM
Just curious to see how high the numbers get with you turbos. Has it ever been so high that you were scared? Just wandering for future reference.
Old Sep 5, 2002 | 06:52 PM
eViLRotor's Avatar
Brother of the Rotary
Running 14psi.
Not really scary though, since its not even the sweetspot on my turbo (KKK)...could be running 18+
Old Sep 5, 2002 | 06:58 PM
peejay's Avatar
Old [Sch|F]ool
I drove my Isuzu once with the wastegate disconnected... no boost gauge, but holy christ in a handbag did it have some serious mid-range torque, at least until it blew the EGR tube out of the exhaust manifold and one of the intercooler hoses came off as well.
Old Sep 5, 2002 | 07:48 PM
Im pushing 15lbs on the street and 18lbs race on a mostly stock car.the only problem i have is vac lines needed hose clamps
Old Sep 5, 2002 | 08:03 PM
Roy James's Avatar
My cars louder than yours
How in the hell are you pushing 18PSI on a mostly stock car?
Old Sep 5, 2002 | 09:03 PM
Evil Aviator's Avatar
Rotorhead
73-88psi boost in a Huey (T53 with 6:1 - 7:1 CR)
205psi boost in a Blackhawk (2 x T700's with 15:1 CR)
Boost isn't scary; I am.
Old Sep 5, 2002 | 09:10 PM
Fox4Life's Avatar
wow, compared to some of these guys i feel like a wuss now. i run 11-12 PSi with mildly modded car. and it feels fast to me. Not scary, but fast.
Old Sep 5, 2002 | 09:23 PM
I wish I was driving!
I run 10 psi, but it skyrockets when I hit nitrous. I compensate for the added boost by running majorly rich on my wet side fogger. Its a crappy setup, but my EGT's like it.
Stock ECU and injectors.
Haltech E11 will be going in soon.
Old Sep 5, 2002 | 09:57 PM
DaleClark's Avatar
RX-7 Bad Ass
I've accidentally hit about 1.5 bar - you do the math .
Not to mention a mis-shift that got me to about 9,400 RPM Peak hold electronic doodads are cool, but sometimes they scare you .
Dale
Old Sep 5, 2002 | 10:22 PM
FC Drifter's Avatar
Damaged Little F*cker
when i first got my T2 put together and running my wastegate actuator wouldnt open the wastegate. i pegged my crappy autometer boostgauge. thats like 20psi i think, on a stock turbo. im surprised the engine didnt blow, or even the turbo.
Old Sep 5, 2002 | 10:25 PM
BlackFC's Avatar
In the Talon on race gas i pegged the 2.0kg/cm^2 boost gauge atleast 3 - 4 times a weekend for 1 - 2- 3- 4th gear pulls (28.44psi). Stock bottom end and stock HG with cams and ARP studs. On pump gas I was sticking it around 19 - 20psi.
There are some things I miss about the Talon
Daniel
Old Sep 5, 2002 | 10:33 PM
FC Drifter's Avatar
black FC, you wouldnt want to see it now. the retards that tuned it made it slower. on pump gas it couldnt beat Chris's WRX. the guy thar bought it let the local DSM "experts" tune it and the only way its fast now is when its on race gas.
Old Sep 5, 2002 | 11:51 PM
j spec monkey's Avatar
i was running about 18-19lbs on my last jspec and it loved it only thing .....prolonged exposure to those levels tend to eat up stock s4 turbos.... just put in a s5 block with s5 turbo and ive pushed 16lbs so far without as much as a tick so we'll see how that turns out
Old Sep 6, 2002 | 01:45 AM
Barwick's Avatar
SCCA Rookie
5.5 lbs till it boost creeps.. not sure why the DSV isn't working correctly (don't think it is anyhow..) but it ran 14.1 @ 100 mph on that boost.. surprised the crap out of me.
Old Sep 6, 2002 | 01:56 AM
Scott 89t2's Avatar
SOLD THE RX-7!
I hit 15psi once when the nipple thing poped out of the turbo . scared the **** outa me cause it wouldn't idle when I stoped to figure out what the hell happened. luckly I caught it while it was going up. and I was only at like 30% throttle
some JB weld fixed that back up
Old Sep 6, 2002 | 08:11 AM
The Ace's Avatar
Greek Power
hehehehe....normal for me (now) is 0,65bar (9,5psi), but a week ago I could hit 1bar (14,5psi) easily ....
....luckily I did find out that my wastegate was disconnected
dre_2ooo's Avatar
Well I don't have a turbo but the VDI gives me about 1.75-2.25psi. Does that count?
thanks for all the response, now i have some idea what i can expect later on down the road when i build a trubo!
Old Jun 26, 2003 | 10:10 PM
dr0x's Avatar
pei > caek
7psi.... I dont want to run more for another 2000km yet.
Old Jun 27, 2003 | 01:41 AM
Manolis_D's Avatar
19psi on 91 octane gas. I usually run 14-15 though, occasionally up to 17 if i'm feeling rambunctius . S5 TII with a 60-1 / E6K.... car actually makes less power at 19psi 'cause it's sooooo rich.
-Manolis
Old Jun 27, 2003 | 04:37 AM
ViRuS's Avatar
Damn! You guys run hellzaaa boost!! How long do your engines last. Im only at 8.2psi peaks to 9psi in 4th and 5th not sure why but thats how it always goes. Seen guys running 14 + and I hear later about a new motor in the works. But I dunno. How much can the stock Turbo and injectors take (s4) I think 10 is stressing them. IMO
Old Jun 27, 2003 | 06:07 AM
T2 Tsunami's Avatar
Stud Service
Now I'm wondering. Are all yall guys running 10+ PSI, also running FMIC's?. I've got a **** load of stuff done to my S5, but have heard several times that I should'nt take it past 10 PSI until I get a FMIC and possibly a stand alone. So what's the scoop on this. What are yall running to go that high on boost?
Old Jun 27, 2003 | 10:50 AM
Before I ported the wastegate on my stock s4 turbo, I'd always hold back at 10psi. Once though, when I wasn't paying attention, I hit about 14~15psi. The previous owner said he hit 18psi by accident right after he installed the FCD, lol. Now with a ported wastegate, and a MBC, I hold steady at 10psi. I want more boost, but I'm scared to go higher with my current mods.
Old Jun 27, 2003 | 11:05 AM
pillage6's Avatar
Daily: 12 lbs.
One time I hit over 20 when MBC wasn't hooked up right, almost killed the people next to me when the tail got loose.
Old Jun 27, 2003 | 12:30 PM
West TX RX-7's Avatar
Da Monee Pit
6-10 with stock engine. When I get the car back from MArvelspeed and broke in and tuned i'll probably not go over 15. The motor is being built to handle more but there shouldn't be a need to go more than 15. Your just lowering the life of the engine if you do.
