s4 and s5 timing gears for the e-shaft, same size?
Old Sep 4, 2002 | 07:48 PM
billzrx7's Avatar
I need to know if the timing gear taht goes on the ecentric shaft on a s4 and s5 are the same, i am thinking this is the cause of my timing not being able to stab right no matter how i try it.
Old Sep 4, 2002 | 08:11 PM
peejay's Avatar
Old [Sch|F]ool
Did you install the gear yourself? It's possible that you put the gear on backwards.
The gear is the same for pretty much all rotaries, from the FD engines all the way back to the 70's. (Part # 11-5310-0839)
Old Sep 4, 2002 | 08:13 PM
billzrx7's Avatar
well heres the thing, it keeps timing per say but its always off . would that be the case if it was on backwards?
Old Sep 4, 2002 | 08:23 PM
peejay's Avatar
Old [Sch|F]ool
i assume you mean you don't have enough adjustment to get it set properly?
Old Sep 4, 2002 | 08:28 PM
HAILERS's Avatar
HAILERS
I have myself f....ed that installation up and put it on backwards. The result was no matter how I stabbed the cas, I could not get enough rotation of the cas to set the timing. I had to get a rotary file and make the groove about a eight to a quarter inch longer. Car has been running just fine for the last three years. Wifes car. Never has problems.
Old Sep 4, 2002 | 08:42 PM
billzrx7's Avatar
so if its on backwards it WILL not time right on the money?
FD7KiD
15
Feb 26, 2021 10:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
