Caught my Pulsation Dampner
Old Sep 2, 2002 | 05:28 PM
88 SE's Avatar
EVERYONE SHOULD CHECK THEIRS
Pull off the plastic cap and make sure the screw is still in. Look what I found on mine
AS you can see the screw fell out and was probably leaking. The car did have a VERY strong fuel smell, FYI.
Luckily the engine is bieng rebuilt and I caught this after deciding to inspect it after reading a bunch of horror stories.
Old Sep 2, 2002 | 06:57 PM
blackdragonsocal's Avatar
the screw falling out does not mean your PD is leaking. It's a common problem with the S4 PD's. When people start screwing the screws back in and cranking down on them that's what tears the rubber in the PD and makes it leak. Good job catching it while you got your motor apart....if you're looking to upgrade your fuel system I recommend you check out RETed's site (www.fc3s-pro.com) and look at his picture of the parallel fuel rail system.
Old Sep 2, 2002 | 07:02 PM
88 SE's Avatar
Yea I used some water to see if its leaking or not, it wasnt. BUt of course, it might under pressure I dunno.
Is it safe to just put the screw back in? how far and how tight should it go?
Old Sep 2, 2002 | 07:24 PM
peejay's Avatar
Old [Sch|F]ool
DON'T put it back in. You could easily tear the diaphragm and CAUSE it to leak.
Old Sep 2, 2002 | 07:28 PM
88 SE's Avatar
So whats the point of the screw then ? :P
Old Sep 2, 2002 | 07:45 PM
silverrotor's Avatar
When the screw fellout to my PD I carefully screwed It back In and put a dab of clear silicone on It. No problems eversince.
Old Sep 2, 2002 | 10:49 PM
IMHO everyone with a S4 should replace the PD with a banjo bolt (Earls Part #997591). If you check out RETed's page you can see from the animated gifs why the screw falling out has nothing to do with making the PD leak. http://fc3s-pro.com/TECH/FAQ/pd.htm
Old Sep 3, 2002 | 01:06 AM
88 SE's Avatar
Just to be on the safe side im gonna replace it.
The car reeked of gasoline before and the end cap (the yellow plastic thing) had obviously been exposed to gasoline. The car wasnt very well taken care of either.
ls1swap
Jun 3, 2024 03:25 PM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
FC_DREAMS
20
Sep 22, 2015 09:43 PM
incubuseva
14
Sep 3, 2015 12:37 PM
