HEEELLLLPPPP!! I am desprite!
Old Aug 27, 2002 | 10:58 PM
gz91rx7's Avatar
Ok here is the thing. I am installing a deck into a 81 rx7 and I have trimmed the dash to fit the cage, but it looks like there is a bracket that sticks down on the top corners behind the radio opening. I just dont know about the screws that hold the bracket in place that are in the way.
I wish I had a pic! I hope that someone out there has had to deal with this!!
Any other ideas for this install are more than welcome!
Thanks,
Josh
Old Aug 27, 2002 | 11:05 PM
Directfreak's Avatar
I am a Jeeper Now.
Are putting it in the top, or the bottom. Also, PM Mike-P-28. He's the pro-installer here.
Old Aug 27, 2002 | 11:08 PM
gz91rx7's Avatar
Top i guess. thanks for the help with mike.
Old Aug 27, 2002 | 11:35 PM
I am a Jeeper Now.
If I remember correctly from my '81 and '83 - it has to be trimmed inside to fit a regular DIN Sized radio.
Old Aug 27, 2002 | 11:40 PM
S2-13BT's Avatar
Yep, there are mounting points on each side for the dash trim. You need to grind these down, a fair bit to fit a DIN sized deck in there. That's why I went with the bottom location for my stereo (cause I'm a lazy SOB).
That doesn't mean you can't put it there, in fact it probably is better in the top because you'll have better access to it.
Good luck.
Old Aug 28, 2002 | 10:27 AM
gz91rx7's Avatar
Thanks!!!!
mark another one down for forum!
manny34711
39
Dec 2, 2005 02:00 AM
Rx7_Nut13B
South RX-7 Forum
Jul 4, 2005 12:43 PM
Rx7_Nut13B
Jul 4, 2005 09:40 AM
Rx7_Nut13B
Jun 14, 2005 09:43 PM
