How much pwr do we lose on during these HOT ASS DAYS??
Old Aug 18, 2002 | 05:55 PM
How much pwr do we lose on during these HOT *** DAYS??
My car runs like garbage like right now when its 90+ out and sticky.
Just venting..anyone else get this?
Old Aug 18, 2002 | 05:58 PM
vaughnc's Avatar
knowledge junkie
Have the FULL cold air intake, cold air box, & cone filter will help with that.
Rotaries seem to have more low end torque on colder days, but the topend HP doesn't seem to be affected.
Old Aug 18, 2002 | 06:01 PM
That sounds about right. In my opinion, rotaries seem to be affected by intake temperature more than piston engines.
Old Aug 18, 2002 | 06:12 PM
i agree on that.
i have a cone filter, but i deffinally have to construct a cold air box.
i have seen the how-to's on making the cold air box, has anyone done it with sheet metal?
Old Aug 18, 2002 | 06:44 PM
Digi7ech's Avatar
I break Diff mounts
You think 90 with humidity is bad. Try driving your car in Arizona with almost no humidity and 100+ temps. It runs much hotter cause of no humidity. I just put a new Thermostat in and I'm running at about 200-210 now.
Old Aug 18, 2002 | 07:03 PM
vaughnc's Avatar
knowledge junkie
Digi7ech,
I though mazda installed e-fans one rotaries sold in the hotter states?
Have you considered & coolant flush Seriously I was runing 220 before I did that in GA's heat.
Old Aug 18, 2002 | 07:09 PM
ROTA_MOTION's Avatar
just be bloody happy. its friggin cold and freezing over here. i will trade some cold weather for some hot!!! but damn the car runs good
Old Aug 18, 2002 | 07:16 PM
13bpower's Avatar
s4 for life
In that respect I am glad I live in mild Washington state.
Nothing like starting my car up on a 50 degree night. Much more power than when it is 90 degrees out.
Old Aug 18, 2002 | 07:38 PM
i live in ny, so i get the best of both climates.
in the winter i get awsome boost.
were in a little heat wave now, it sucks
Old Aug 18, 2002 | 07:49 PM
WonkoTheSane's Avatar
Green Flameless
here in central PA, just about every day is 90/95 and 85-95% humidity.. i hate this state.
Old Aug 18, 2002 | 08:50 PM
tell me about it ... about 3 or 4 o clock in florida it sucks.... i feel like im killing my car.. come 7 am when i just start it up.. it feels great!!!!!!!!!!!!! i cant explain the feeling! and then at 9 pm too... the air fuel gauge.. shows slighty leaner also.. i guess the intake sucks more air anywayz at colder temps outside
Old Aug 18, 2002 | 09:22 PM
BDoty311's Avatar
88 AE
How much power do you lose on hot *** days??
A general rule of thumb is 1% for every 10 degrees fahrentheit(sp?)
Well atleast thats the truth for piston engines
Old Aug 19, 2002 | 07:48 AM
silverrotor's Avatar
Good question. Anybody?
Old Aug 19, 2002 | 09:27 AM
E6KT2's Avatar
It's actually 1% hp loss for every 11 degree increase in intake air temperature. Most cars are rated at a nominal of 65 degrees, if I remember correctly.
Old Aug 21, 2002 | 12:56 PM
darkwaveboi's Avatar
Need donor car in Fairfax
but where is that loss relevent from? 0º? it doesnt mean anything enless theres a temp in which engines run best at.
Old Aug 21, 2002 | 03:11 PM
DaleClark's Avatar
RX-7 Bad Ass
IMHO, that's not the best way to look at it - engines are systems, and the air temperature is just one factor of the system. Suffice it to say hot = bad .
This is one area where a good front-mount intercooler makes a big difference. The stock IC is REALLY bad - you guys just don't know how hot that sucker gets, and how nice and cold a good front-mount will get the air. Makes the car run like it's cold out all the time .
On cold air intakes, IMHO the best route to take is to shield the cone off from the hot engine compartment air, and provide a duct to supply fresh air from the front of the car. Some of the more radical designs end up just being a royal pain in the butt to install and remove, and you really don't gain as much as you'd think. A basic shield will get you all you really need.
Dale
Old Aug 21, 2002 | 03:40 PM
BKC TURBO's Avatar
Speaking of Heat
I was driving my AE Turbo through the desert between LA and Vegas. Probably mid 90's outside. I was driving pretty hard and noticed my temp guage go to middle and just a hair above. I let off immediately and it cooled off. I know i need some real temp guages, but anyone think damage might have been done to the engine or know of something i should check because of that?
Old Aug 21, 2002 | 03:42 PM
Eva Unit 00's Avatar
I know I can tell a huge difference in my talon or my miata. I love those cool fall/spring nights feels like an extra 15hp.. Its been in the 90's here and they both feel like someone stuck a sock in the intake @.@
Old Aug 21, 2002 | 04:21 PM
N1XRR's Avatar
Re: Speaking of Heat
Actually, it seems on days hotter than 85 deg the temp guage always stays at 1/2. This is not just my car either, I've talked to 4 or 5 other TII owners, all the same. I also talked to Greg Burns about it, he said "You run colder that 1/2 way? Huh..." in other words, 1/2=normal...any higher than that is bad. My car goes up a tiny tiny bit in extreme heat, but I don't push it when its that hot out.
In the winter, unless I'm REALLY pushing it then my temp stays at 1/4.
Michael
Old Aug 21, 2002 | 04:46 PM
pip's Avatar
pip
the blackest incarnation
Sometimes on hotter days (and yes it does get hot in WI) I try to not to drive to much, and if I do I dont push her to hard. But then when I the sun goes down I take her out to play
rgordon1979
40
Mar 15, 2022 12:04 PM
Ian_D
Oct 14, 2015 12:31 PM
Monsterbox
Sep 11, 2015 03:29 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
