What tranny and differential do you use.
Originally posted by MaTT_FoULk
Wouldn't that be an automatic? Yuck....
the cosmo auto handles the power great and goes
like mad, it shifts at the red line and will spin the wheels
when it goes for 2nd.
I bet you cant change gears and keep the boost up
I can hold the brake and gas at the same time to build
good boost off the line, launching as good if not better
than a manual trani. It's truly better than I thought it would be
matt
Trending Topics
Has anyone considered using a 'vette gearbox? I believe there is one above the LT-1? called something like a "SW8" ? apparently it's a 6-sp but when you disconnect the sensors to it, it has no protection against going into reverse (if you're concerned about that).
LT-1 was an engine from 1970, unless you want a Muncie 4-speed (not a bad idea, really) then it's not a good plan.
The LT1 from more recently is also an engine, not a transmission. In the Corvette it had a bulky, expensive ZF transmission, and in the Camabird it had a Borg-Warner T56.
mike
