Drain And Refill
Old Aug 12, 2002 | 12:43 PM
xtremespd's Avatar
Drain And Refill
The other day i drained and refilled my tranny in my tII with some nice clean GL-5. I also did the rear differential.
It made one hell of a difference. But i do have a question. There are 2 check and drain plugs on the tranny i only did the front one and didnt check the back plugs. Should i or should i leave it alone. What is it for and what fluid would it Take. Thank you.
Old Aug 12, 2002 | 01:22 PM
Turbonut's Avatar
Take both out. fill the front until it flows out the rear. If you fill the front full, you will have overfilled the trans and under pressure, fluid will be expelled.
Get car level, and remove the rear plug and let excess fluid drain.
When my '89TII was new, dealership did the same thing, removed on front plug. As I pulled in my driveway I had smoke coming from under the car. Fluid on exhaust. I removed rear plug and watched the excess drain out.
Old Aug 12, 2002 | 01:31 PM
xtremespd's Avatar
i see. i'll check that next time im at work. i filled the front untill it was a slow drip from the front plug. I'll check the level and make adjustments as needed. thank you. How much do redline fluids cost and would it be worth it, sould i spend the money.(what i did so far didnt cost me anything)
Old Aug 12, 2002 | 01:42 PM
banzaitoyota's Avatar
What Subscription?
redline is 7-8 a quart well worth it.
Old Aug 12, 2002 | 01:50 PM
deadRX7Conv's Avatar
Opinions are like........
Redline/amsoil/mobil1 gear oils cost between $5-$12 a quart. It depends if it is available in your area. There are plenty of mail order sites that carry it. I prefer to give my business to the speed shops/autopart stores in the area first.
The synthetics work better than the cheapo oils.
Its your choice if you want to spend money for slightly better protection or just stick with the free changes.
Old Aug 12, 2002 | 01:56 PM
What Subscription?
Neo is also A good choice.
Old Aug 12, 2002 | 02:07 PM
Turbonut's Avatar
I also use redline. In my climate, it's been great winter/summer.
Make sure you use the correct one for the trans and for the rear (a/c posi).
Old Aug 12, 2002 | 07:52 PM
RETed's Avatar
Watch it - GL-5 is not good for the transmission unless EXPLICITLY stated on the container.&nbsp GL-4 is the proper fluid rating for transmissions.
-Ted
96fd3s
38
Apr 19, 2021 06:50 AM
NotMrButts
23
Sep 15, 2015 09:46 PM
