TMIC water cooled with nozzle/water pump ?
Old Jul 24, 2008 | 10:52 AM
Malefoda's Avatar
Weight Watcher
Hi there,
Is there any try at water cooling the TMIC with an added water mist system?
If yes how it was done?
Cheap kit, easy DIY tips...
I've my rear glass tank & pump in hand (faulty contact or cut wire at command so removed as it's not a security or performance device) and such idea came to my mind...
Thanks!
Old Jul 25, 2008 | 07:44 AM
Malefoda's Avatar
Weight Watcher
Using used parts as front hl whaser pump and maybe the SARD Nozzle at TMIC front should do it?
http://www.more-japan.com/SARD-SCS-O...y-p-16975.html
Old Jul 25, 2008 | 01:35 PM
freemanrx7's Avatar
^Hold On
Intresting. I'm curious to see if someone has done this. It may help in certain situations like waiting in line at the drags.
Also don't wrx's have this setup from the factory?
Old Jul 25, 2008 | 01:57 PM
Ry87TII's Avatar
Yea the STI came with it from the factory starting in 04 so maybe you could look into how that was done on those cars
Old Jul 25, 2008 | 02:01 PM
Malefoda's Avatar
Weight Watcher
I've been said Lancer Evo ans Impreza have it as OEM...
Old Jul 25, 2008 | 02:37 PM
FRFC3S's Avatar
Partout Performance
My buddy used his rear whiper pump and hooked a switch and poked a bunch of holes in a line and wrapped it around his TMIC.
It spritzes water a little bit, give him a PM at Andy87t2 and see how much he likes it.
Old Jul 25, 2008 | 02:43 PM
freemanrx7's Avatar
^Hold On
Well it must be effective if they put it on from the factory.
Can anybody chime in who has seen this or has done it?
Old Jul 25, 2008 | 02:51 PM
Malefoda's Avatar
Weight Watcher
I'll go for a real mist-able nozzle or won't
But I also wanna try with the pressure from the rear pump.
Wicked93gs
44
Jan 12, 2022 10:08 AM
Th0m4s
Feb 26, 2019 02:04 AM
rotor_veux
Sep 3, 2015 07:10 PM
rotor_veux
Aug 31, 2015 07:49 PM
