Rotary Drag Racing The place to post your racing stories and info
C4 auto to 13b rew quick question
Old May 15, 2008 | 11:41 AM
  #51
sk8world's Avatar
Chasing numbers
Whats the cost differance in g-force and other such units? I am ready to start this conversion but want to make sure on whats the best for me.
Old May 15, 2008 | 12:02 PM
  #52
Viking War Hammer's Avatar
*** Bless The USA
Judge Ito was selling his G-Force transmission awhile ago, I looked into buying it................ but it was $9,000 used.
Old May 15, 2008 | 08:15 PM
  #53
sk8world's Avatar
Chasing numbers
wow. Thats more than I want to spend on my weekend warrior. I and when I get serious about racing I can see going that route. So I contacted Redneck and they had no clue about rotary's or if the imput shaft would work. Basically said we can not help you in that area. ?? I thought these guys did a few? Or was it other turbo cars you were speaking of?
Old May 15, 2008 | 08:23 PM
  #54
*** Bless The USA
Redneck doesn't do the rotaries. They just sell built C4's.
Carribean sells the rotary C4 conversion kits.
Old Aug 4, 2008 | 04:30 PM
  #55
*** Bless The USA
Picked up a auto bellhousing finally.
Does it matter which C4 I use, a pan mounted dip stick or pump mounted dip stick?
Old Aug 5, 2008 | 09:24 AM
  #56
13BT_Starlet's Avatar
I would use the case dip stick rather than pan due the fact that the pan style case is the large bellhousing ford style and you will run into clearences problem with the starter which you alerady have with the small bellhousing case one which you have to do some trimming but not mutch , check out the pics I posted on this thread its the case dip stick style.
Old Aug 5, 2008 | 12:03 PM
  #57
*** Bless The USA
Thanks a bunch. I'm going to have someone local build the converter. The bungs on your converter, could you possibly measure how tall those are?
Is there anymore information they gave you about the converter?..... or did they just say it's a 6500 Converter? Anything about the bearing design, balloon plate, hardened splines, stator or sprag assembly?
Have you weighed yours?
Thanks dude!
Old Aug 5, 2008 | 03:41 PM
  #58
*** Bless The USA
FYI, for anyone interested.
I've found a converter race shop that has recommended doing the following. Doing it this way would allow direct mounting to your stock flexplate.
I would send them my stock 13B Torque Converter.
They would use the front half of the stock 13B converter.
They would install C4 guts and put the *** end of a C4 converter on.
Old Aug 5, 2008 | 07:46 PM
  #59
*** Bless The USA
Alright, www.dirtydogperformance.com
I just talked to him again, he's going to mail me a C4 hub so I can take measurements. Then, I'll send him the stock RX7 Converter so that he can build me a custom unit. It's going to be a light weight 9 inch 6500 converter.
He said it will be $500. Not bad, huh
I'll make a new thread, showing how to re-drill the stock bellhousing ti fit with the C4 pump etc. etc.
Old Aug 5, 2008 | 10:44 PM
  #60
ultimatejay's Avatar
9000 bucks! Does that come with a jar of vasoline and a corncob?
Ps. Auto's are for *****'s that can't shift. LOL
Old Aug 5, 2008 | 11:30 PM
  #61
*** Bless The USA
9,000 bucks? Where did you get that figure?
I could shift if I wanted to, but I'd rather make back to back 9 sec passes with a beer in my right hand
Old Aug 5, 2008 | 11:38 PM
  #62
I just don't see a lot of top rotaries using auto's and I think it's because the rotary has a low torque high power band and does not work well with auto's. You see most of the rotaries using auto's are sitting at the lights for like 5 seconds trying to get the boost up- race is over by then. hehe. You're also adding quite a bit of weight and rotating mass.
Old Aug 6, 2008 | 09:59 AM
  #63
*** Bless The USA
oh yeah, his gforce was expensive....... way out of my league
check out the aussie guys and the ricans, those guys have good luck with autos....... its all in the converter selection
what's a little rotating mass if you've got consistancy? refer to erniet
Old Aug 6, 2008 | 09:04 PM
  #64
Thats the hole concept of the rotary to c4 tranny converter , mine has the stock S5 AT converter with the c4 guts and c4 pump inout shaft .
Old Aug 6, 2008 | 09:24 PM
  #65
I just don't see a lot of top rotaries using auto's and I think it's because the rotary has a low torque high power band and does not work well with auto's. You see most of the rotaries using auto's are sitting at the lights for like 5 seconds trying to get the boost up- race is over by then. hehe. You're also adding quite a bit of weight and rotating mass.[/QUOTE]
I am not sure if you are familiar with Lowe Performance , but anyways He runs a AT Tranny and is in the 7's . In my book is all in having the right combo it's going to take alot of time to find out the right tire size along with the right gears to meet with your engine power band . I have yet to see anyone put a car together to run a specific time and done it the first time out , I take alot of effort and changes . I have been to quite alot of events and seen alot of highend $ car with High $ tranny's and still have hard time getting to shift and miss gears .
Old Aug 6, 2008 | 09:28 PM
  #66
What car and Tranny combo you got ? Post up some pics of your setup maybe it might change my mind and go the other route , but for now I'm staying with the AT
Old Aug 6, 2008 | 10:50 PM
  #67
*** Bless The USA
Really? See, I thought you had a C4 converter with custom mounts
My bad !
Old Aug 6, 2008 | 11:05 PM
  #68
*** Bless The USA
Check out this C4 powered rotary
http://www.youtube.com/watch?v=oxwaQ7uWBkQ
Old Aug 7, 2008 | 02:05 AM
  #69
sk8world's Avatar
Chasing numbers
I will post this here also.. Thinking of a future project RX3. What do you think? Would be a drag car only. I can pick it up very cheap..??
Attached Thumbnails C4 auto to 13b rew quick question-0517_182238.jpg   C4 auto to 13b rew quick question-0517_182050.jpg
Old Aug 7, 2008 | 02:17 AM
  #70
mazda1200's Avatar
nice car...
Old Aug 7, 2008 | 02:41 AM
  #71
rotorholic's Avatar
DPG Burnout
how cheap?
passing thru alabama early next week
Old Aug 7, 2008 | 08:27 AM
  #72
*** Bless The USA
13B C4 Automatic Video ........... cool
http://www.youtube.com/watch?v=pSRSIUEoWgg
Old Aug 7, 2008 | 08:28 AM
  #73
*** Bless The USA
C4 13B............ 9.90@ only 133 mph........ http://www.youtube.com/watch?v=zJh-MWUs9mk
who says you don't have to shift a auto ....... haha
Old Aug 7, 2008 | 08:35 AM
  #74
*** Bless The USA
More C4 13B's and wildness....... Red car has a C4
http://www.youtube.com/watch?v=roki_vEpy0U
Old Aug 7, 2008 | 08:36 AM
  #75
*** Bless The USA
C4 13B car on the dyno, check out the fire.....
http://www.youtube.com/watch?v=wZb7POiufdc
