removing front cover
Old Mar 26, 2006 | 08:34 PM
3rd and final 7's Avatar
wheres the water goin?
i ve pulled my engine and put another in and now im dismantling my old one and i cant seem to get the front cover off. i ve pulled all the bolts from the cover and the oil pan. iis there a trick to gettin it off w/o breaking anything ?
Old Mar 26, 2006 | 08:47 PM
peejay's Avatar
Old [Sch|F]ool
Take the oil pan off first, makes things much easier as you only have to break one surface free at a time.
If someone previously used silicone instead of a gasket, it can be a pain to remove. I actually cracked one trying to remove it, but on the other hand it wasn't leaking, either
Old Mar 26, 2006 | 09:03 PM
Midwest 7's's Avatar
sellout
yea, you need to take the oil pan off.
Old Mar 26, 2006 | 09:04 PM
oh the oil pan is off. its just the front cover is solid stuck on there and id like to start gettin everything cleaned!
Old Mar 26, 2006 | 09:08 PM
680RWHP12A's Avatar
get a hammer and tap on the studs that stick out below the dizzy, the mounting studs for the ac bracket, that should knock it loose.. the front covers are stuck on pretty good sometimes
Old Mar 26, 2006 | 09:22 PM
cool i ll give it a try tomorrow its 1030 pm right now so i ll deffinately give it a try on my lunch break!
Old Mar 26, 2006 | 09:25 PM
rbf41182gt's Avatar
i just took one off today on my junk engine. i just drove a thin screwdriver in, and worked it around the perimeter, prying a little more each time. But maybe you'd want to be a little more careful if you plan to use it over again.
Old Mar 26, 2006 | 10:10 PM
trochoid's Avatar
Old Fart Young at Heart
You have removed the e-shaft bolt, right? I have a thin, flexable putty knife that I use to break front covers and pans off. I start the putty knife in the middle of the gasket's thickness so I don't damage the mating surfaces.
Old Mar 27, 2006 | 12:59 AM
steve84GS TII's Avatar
FB+FC=F-ME
That was my first thought as well.....
Old Mar 27, 2006 | 08:00 AM
the rest of eng is apart its just the font covr and front iron that are still together
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
morataya
Microtech
Aug 17, 2015 01:04 PM
