need huge favor
Old Jan 31, 2008 | 05:41 PM
t2josh's Avatar
T2** rise of the rx-7
need huge favor
could somebody with an 87 T2 please unplug this from their car and see if it starts i would greatly appreciate that is somebody could do this for me, it would answer a lot of questions. it is located in the driverside shocktower.
Old Jan 31, 2008 | 05:44 PM
boostedfc3s's Avatar
1.3 liter piston eater
sure give me about an hour or so till I get home from work.
Old Jan 31, 2008 | 05:48 PM
Sideways7's Avatar
Yes, it will still start. That is a non-essential part. All it does is smooth out the oil pressure gauge and protect it from a faulty pressure sender. The car will run the same without it.
Old Jan 31, 2008 | 05:52 PM
t2josh's Avatar
well the my car wont see to start, it isnt gettina spark and all the coils are good and gettin power, any ideas?
Old Jan 31, 2008 | 05:53 PM
texFCturboII's Avatar
version 2.0
In the driver side shocktower? Does that get terminated by a bolt through that eyesocket? Where does the connecotr plug into?Answer these questions and I think you may have a better chance of getting your car started, plus provide more details about what you have checked, what it does when you try to start it, list the mods you may have done......
I've got no idea what that is!
Old Jan 31, 2008 | 05:54 PM
The Wankler's Avatar
FKITALL
You need to be more descriptive.
Old Jan 31, 2008 | 06:00 PM
t2josh's Avatar
well all it has is full racingbeat exhaust, when i was driving it the first 45 miles i had it about 3 times it would just die while driving and i would push the clutch in and let it go and it would start back up and all the warning lights came on and stayed on, would a bad alternator cause it to not start, i mean it turns over fine just wont start
Old Jan 31, 2008 | 08:23 PM
HAILERS's Avatar
HAILERS
All warning lights on means the alternator isn't working for one reason or the other. Belt fall off?
Turning over and not starting wouldn't be the alternator though. Shoulda started if the fuses are all good. The EGI fuses in the engine bay and the Engine fuse in the interior.
Or it could be you ran out of gas. Or something else.
Old Jan 31, 2008 | 09:25 PM
dazed01's Avatar
I
You're getting no spark? Any signal from the CAS?
Old Jan 31, 2008 | 09:36 PM
RETed's Avatar
Not entirely correct...
There are two of these things, and what you are describing is the other one.
On a Turbo II, it's supposed to be bolted onto the clutch slave cylinder.
The one the OP is describing is for the trailing coil pack toggle.
And everyone else is right...it doesn't matter if this is connected or not; it does not interfere with the car cranking or running.
It just minimizes any pulsing through the electrical system due to the toggle in the trailing coil pack.
-Ted
Old Jan 31, 2008 | 10:07 PM
K-Tune's Avatar
FD Daily
mine drives every day without that thing!
Old Jan 31, 2008 | 10:47 PM
Azn_Boi's Avatar
Bad alternator would cause the car to die once the juice in the battery are gone. Starting a car has to do w/ the battery not the alternator. Alternator keeps the car running after starting.
Old Feb 1, 2008 | 05:55 PM
t2josh's Avatar
so all the fuses are good and gettin power, the only thing i havent checked is the cas, what are the chances its bad as well?
Old Feb 1, 2008 | 06:19 PM
polito Racing's Avatar
so you got pistons oh wow
if the alternator was bad the car wouldnt push start. and it would have gotten to the point where the battery was so drained it wouldnt even turn anything on. when i first got my car it was doing something similar it ended up being the ignition swith. if you have a lot of keys in the key chain this will happen eventually. i think i might still have one harness arround here somewhere let me know if you need it.
Old Feb 2, 2008 | 06:29 PM
t2josh's Avatar
ok so i just checked the CAS and it is good both sides about about 155 ohms, all fuses good including engine bay fuses, im starting to think its the control module or the igniters, and suggestions?
NotMrButts
Feb 10, 2018 06:36 PM
c0rpse
16
Sep 25, 2015 11:33 AM
FC_DREAMS
General Rotary Tech Support
20
Sep 22, 2015 09:43 PM
