Time Slips
Old Aug 5, 2004 | 07:12 AM
  #76
jacobcartmill's Avatar
just dont care.
thanks i wasnt aware that there was an FC section.
Old Aug 12, 2004 | 06:01 PM
  #77
jantore's Avatar
Got some times for the first time this year, today. At Gardermoen Race Way Norway.
It's been prepped for the last 4 weeks cause of European Championships last weekend.
My fastest time was.
60" 1.790
1/4mile 12.645 and 182.27km/h(113.91mph)
I have some problems with the gearbox, it get stuck for a split second before it pops into second and third. So im loosing some time. A 1.790 60" should give me a better ETA.
The time was made with 15psi of boost on a Trust TD06H-25G singel turbo and Bridgestoen RE540S street slicks.
Old Sep 12, 2004 | 11:27 AM
  #78
radkins's Avatar
I took pass for the first time with my single turbo on and did a 11.9@123 the first time. That was good enough fo me so that's all I ran. This was at Muncie Dragway in Muncie Indiana.
Old Sep 13, 2004 | 04:04 PM
  #79
Gargamel's Avatar
what boost, turbo?
Old Sep 14, 2004 | 06:08 PM
  #80
radkins's Avatar
Originally Posted by Gargamel
what boost, turbo?
XS TO4S. 16-17lbs
Old Sep 14, 2004 | 06:35 PM
  #81
Gargamel's Avatar
Didn't you put down like 470 to the tires with that boost level?
Old Sep 14, 2004 | 08:24 PM
  #82
radkins's Avatar
465 at 18-19lbs
Old Oct 6, 2004 | 11:33 PM
  #83
Rotarded's Avatar
"Challenged" since 1993
A new best!
Ran an new best time tonite!
1.03 bar peak boost (from PFC)
1.771 60' (ET Streets)
11.835 ET
116.35 MPH
Mike
Old Oct 7, 2004 | 11:56 AM
  #84
BlackRX7Turbo's Avatar
Originally Posted by ForceFed
Dizzy, I ran 13.5 bone stock with a *boost problem*! With your mods you should have a Apexi Power FC and you should be running atleast 12.9 ETs. Hell my stock RX-7 has a 12.9-13.0 in it with some slicks so you should be running a solid 12.9 ET on street tires.
Shift at 7K in first gear, ride 2nd out to 8K then shift 3rd at 7500. Also, it sounds like you are getting wheel hop in 1st and 2nd gear. Try launching by bringing the car up to 4000-4500rpm and SLIP the clutch coming out of the hole. Also if you are on street tires GO AROUND THE WATER BOX and don't do a burnout. This will help you.
When shifting, are you lifting off the throttle? Are you clutching in? If you're hitting 13.5 bone stock, I figure 13.0 or maybe a little better for me if I can figure out how to drive...
what inflation were you tires?
Old Oct 9, 2004 | 08:31 AM
  #85
adictd2b00st's Avatar
boost > *
ran my 3rd gen for the first time (got it about a month ago). 12.92 @110.6 with a 2.0 60' on street tires. does that sound about right for a street ported motor running 11psi with intake/full exhaust?
Old Oct 28, 2004 | 09:55 AM
  #86
matty's Avatar
i really question the performance increase of a street ported motor on stock twins.
Old Oct 28, 2004 | 06:10 PM
  #87
fastrx7man's Avatar
Looking for 10's
That's pretty strong for what you have had done. Now get a FMIC, upgrade the fuel and ignition system, up the boost a little, dump in some VP Red and go for 11's.
Old Oct 28, 2004 | 06:17 PM
  #88
fastrx7man's Avatar
Looking for 10's
11.835 ET
116.35 MPH
Mike
Nice time 14.65 lbs of boost ... I didn' see a upgraded diff in your list of mods. You are going to need one when you start running those times with that type of 60'. I broke my stock diff running about the same time.
Old Oct 31, 2004 | 12:48 PM
  #89
racerfoo's Avatar
i trapped 111 with no street port, and 10psi boost. my car is on a slight diet tho (no a/c, p/s, airpump)
Old Oct 31, 2004 | 04:38 PM
  #90
matty's Avatar
i trapped 110 mph with intake fulll exhaust power fc @ 12 psi no street port. i know people that have done better with same mods no port work.
Old Nov 2, 2004 | 11:28 PM
  #91
Rotarded's Avatar
Blew the diff that nite. Got a S4 installed and gonna try to go lower!
Old Nov 10, 2004 | 09:08 AM
  #92
radkins's Avatar
Great times Mike! Those ET's must really do the job.
Old Nov 10, 2004 | 09:12 AM
  #93
Rotarded's Avatar
Thanks Ryan. The ETs really hook, but you lose a little MPH.
Did ya find a donor car??
Old Nov 12, 2004 | 08:55 PM
  #94
DeviousDevice7TT's Avatar
Talking
I ran a 13.6 @ 103 w/ a 2.1 60 foot
at 11 Psi
My mods:
DP,MP,PFC Exhuast
225's tires set at 23psi
Here's the track
https://www.superhonda.com/photopost...es_006-med.jpg
Here's my slip
https://www.superhonda.com/photopost...es_014-med.jpg
Old Nov 13, 2004 | 05:43 PM
  #95
just dont care.
Originally Posted by sk8world
12.3 @ 108 with 1.89 60 foot. Stock motor and turbos. HKS F-con, Pettit IC, Pettit intake, DP, MP, Catback, profec B. More, but thats about it for power add ons.
do you know what your 1/8th mile ET/mph was for that run?
i'm trying to figure out what an 8.18@85 in the 1/8th would equate to in the 1/4.
Old Nov 13, 2004 | 08:51 PM
  #96
ForceFed's Avatar
Useful formula for estimating 1/4mi ETs.
1/4 mile ET = (1/8 mile ET + 0.22) / 0.665
So in your case you would have run close to a 12.63. Your mph can't really be accurately calculated but I would take a wild stab in the dark and guess you would have trapped about 109-111.
Old Nov 13, 2004 | 10:14 PM
  #97
birdy01's Avatar
Birds can DRIFT YO...!!!!
13.3@101 with stock motor/turbo w/intake, DP, catback and petitt ecu on street tires
Old Nov 13, 2004 | 10:46 PM
  #98
ForceFed's Avatar
What was your 1/8th mi ET and trap on that run?
Old Nov 26, 2004 | 11:06 PM
  #99
Venom-X1's Avatar
RotorRocket
sup, finally went to the track for the first time. Only got in 2 runs.
Run 1:
2.347 60'
13.294 1/4
110.92 mph
Run 2:
2.132 60'
12.742 1/4
112.51 mph
Then it started to rain.
Old Nov 27, 2004 | 02:58 PM
  #100
Erdin's Avatar
Water Injection Specialist
Smile
Run 1:
2.347 60'
13.294 1/4
110.92 mph
Run 2:
2.132 60'
12.742 1/4
112.51 mph
What are your mods mate
