GT35R Kits (ask anything relevant to 35R's or kits in this thread)
Old Nov 7, 2005 | 10:30 AM
  #51
Zero R's Avatar
Just in time to die
I will get work started on the turbo today. Did you want everything heat coated? I know you discussed it, but it was never officially said to go ahead and ceramic coat everything.
Old Nov 7, 2005 | 11:40 AM
  #52
GoRacer's Avatar
Speed Mach Go Go Go
^yes, heat coat everything possible, blue 46mm Tial w/g if possible. Will the kit fit with the ground zero intake manifold?
Old Nov 8, 2005 | 10:39 AM
  #53
Zero R's Avatar
Just in time to die
I would assume it would fit unless that manifold sits out alot further. The wastegate is silver, they didn't have blue in stock.
-S-
Old Nov 8, 2005 | 07:29 PM
  #54
GoRacer's Avatar
Speed Mach Go Go Go
It sits more forward towards the engine and the runners are strait. I don't know if it sticks out more. I'm trying to find their website or info on them now. Can someone please post?
Old Nov 8, 2005 | 10:13 PM
  #55
Zero R's Avatar
Just in time to die
I will talk to Ralph about it tomorrow.
Old Nov 11, 2005 | 12:32 PM
  #56
GoRacer's Avatar
Speed Mach Go Go Go
^ scratch that idea. It looks like it looses both air pipe and ACV connections which defeats my custom T4 manifold purpose. ok, so we got RS wheel, dump to dp, heat coating, 1.06 snail, waiting on v-band, then ready to ship?
Old Jan 20, 2006 | 04:50 PM
  #57
RotaryBuddha's Avatar
CURVE OF CONSTANT WIDTH
the downpipe that comes in the kit. what exaclty would it bolt up too? or do we have to weld on our own flange.
Old Jan 21, 2006 | 03:41 PM
  #58
Zero R's Avatar
Just in time to die
The midpipe?
Old Jan 21, 2006 | 04:35 PM
  #59
Originally Posted by Zero R
The midpipe?
you mean the stock midpipe?
Old Jan 21, 2006 | 05:48 PM
  #60
demahfahbun106's Avatar
Psychotic CRITIC™
quick question
you guys ever seen this kit on a 1987turbo II rx7?? would like to know of theres a kit like this for a 2nd gen..thanx
Old Jan 21, 2006 | 05:55 PM
  #61
Psychotic CRITIC™
sorry about that i didnt even check the first page..my bad guys...would it be alright to use an retk 1.7 with a safc2 and 720's pri,890's sec? quick question... with the kit for the fc(35rt4) and (35rs), with the rb turboback exhaust, 720 pri,890 sec, npr intercooler,15psi. stock motor w/ 48,xxx miles.what kind of power do you think would be expected from my car??? just a question would like to get an idea..
Old Jan 21, 2006 | 11:24 PM
  #62
BoostedRex's Avatar
NorCal 7's Co-founder
demahfahbun, yes A-Spec makes a 35R kit for the FC. I've been looking into it since they first thought of making it. The kit is very promising!! I look to have one before the year is out.
Zach
Old Feb 9, 2006 | 12:23 PM
  #63
Zero R's Avatar
Just in time to die
It is very hard to give solid HP numbers I don't like quoting them because every build/tune is different.
-S-
Old Feb 9, 2006 | 03:54 PM
  #64
ZumSpeedRX-7's Avatar
rotary amuse
I was wondering what kit would be good for an all around auto-x, street, and emphasis on drag FD.
Old Feb 12, 2006 | 06:03 PM
  #65
Zero R's Avatar
Just in time to die
I would say look at our 500R setup it is a pretty good all around setup. But wanting a turbo the can auto X and drag are two completely different things.
-S-
Old Mar 9, 2006 | 01:50 AM
  #66
88t2romad's Avatar
(_8(|)
whats the availability of a T4/gt35r (turbo only) im looking to buy like....now!
Old Mar 9, 2006 | 10:07 AM
  #67
Zero R's Avatar
Just in time to die
Anytime just call today. Ask for Ryan, He'll take your order.
-S-
Old Mar 13, 2006 | 05:01 AM
  #68
88t2romad's Avatar
(_8(|)
waitin on payday (2 days)
Old Mar 16, 2006 | 01:06 AM
  #69
blueskaterboy's Avatar
Olympic Muff Diver
i've got an apexi fmic sitting in my room. is that sufficient for a 35rs?
Old Mar 16, 2006 | 09:50 AM
  #70
Zero R's Avatar
Just in time to die
That IC will be fine for most of what you do.
-S-
Old Mar 25, 2006 | 02:50 AM
  #71
SAMIboarder's Avatar
JGTC every day.
question: what PSI spring is in the WG you supply w/ the 35R kit? and what brand WG?
Old Mar 25, 2006 | 03:47 PM
  #72
Zero R's Avatar
Just in time to die
Tial, and they come with a 12lb spring.
-S-
Old Mar 27, 2006 | 02:57 PM
  #73
CCarlisi's Avatar
Rebreaking things
Can it grind coffee?
Old Mar 27, 2006 | 04:12 PM
  #74
Zero R's Avatar
Just in time to die
No sir, sorry. That is only the new, not yet but soon to be released model.
-S-
Old Apr 7, 2006 | 12:55 AM
  #75
JGTC every day.
ok, I thought I knew the answer to this, but re-reading this thread, I do not. What turbine housing sizes are available in T4? Sean, my order has the 1.06 hotside, is that T3 or T4?
