Atkins Supercharger
Old Oct 28, 2001 | 08:05 PM
1stGenRacer's Avatar
Atkins Supercharger
Has anyone ever used the Atkins supercharger? If so, how is it and is it worth the price? I own a first gen 12A and it seems fitting to use with my car.
Old Oct 30, 2001 | 09:14 AM
Madman's Avatar
I personally have never used it although I am 99 percent sure I will be getting one for my RX-2. I have talked to several people who have one and I have heard pretty good things from all of them. Everyone says to get the larger size one though. They are a bit pricey but everyone indicates that they are easy to install and worth the price for reliable performance.
Old Nov 2, 2001 | 04:01 AM
Jeff20B's Avatar
Lapping = Fapping
Just make sure you set up the oil lines properly. Every SC I've seen or known about that has failed, has had a non Atkins oil line on it. Just use the oil pedastal fitting that comes with the kit and you'll be fine.
Dave recomends Amsoil 10W40 in his SC kits. There has been some discussion about oil on this forum (like 10W30 vs 10W40 vs 20W50), but if it works good for Dave, then go for it.
Old Nov 3, 2001 | 06:32 PM
Do I need to use an intercooler with this, I was told by a friend that I should use an intercooler with this setup and I want to know if this is right? Thanks
Old Nov 3, 2001 | 07:21 PM
Madman's Avatar
No I really dont think you need to use an IC. Using an IC for a supercharger doesnt give the gains that it does for turbos. You are already drawing in cool air from the outside...
Old Nov 3, 2001 | 10:44 PM
SuperchargedRex's Avatar
Chief Knucklehead
I don't know as much about the Camden blower that Atkins sells, but I can tell you this about the Paxton centrifugal blower that I have: it gets mighty freaking hot. I have burned my hand on the outer casing.
Besides, it is not just the transfer of heat from exhaust gases that increases the charge temp on turbos; the physical act of compressing the intake charge also increases the temp. And for this reason, even a supercharger would benefit from an intercooler.
Old Nov 4, 2001 | 04:11 AM
Node's Avatar
plus friction from spinnning belts and whatnot :-D
Old Nov 4, 2001 | 09:59 AM
Madman's Avatar
In the words of Johnny Carson... I did not know that. I guess you just rarely see people who go to the trouble to use an IC with supercharger setup. With the atkins setup it would be VERY difficult to include to include an intercooler since the carb sits right on top and manifold on bottom. YOu would have really fabricate alot. Just to get back to the question above though if you read through the supercharging FAQ on the page I believe someone asks if it needs intercooled and they say no, it doesnt.
Old Nov 4, 2001 | 10:25 AM
Chief Knucklehead
Gee, I thought I was the only one old enough to know Johnny Carson. As for needing an IC, you can go without one for both turbos and superchargers, you just get better thermal efficiency with one. You're right about placement for one on the Atkins setup. But if I was going to go that route, I'd see if you could fabricate an air/liquid that would sit between the sc and the intake manifold. Just my $.02
Old Nov 4, 2001 | 12:52 PM
Could I still use my nitrous kit with the supercharger or will it have a negative effect. If it helps, It is a NX Hitman plus system. Thanks
Old Nov 4, 2001 | 03:37 PM
Madman's Avatar
Yes you COULD, no it would not NEGATE, but I would be very weary of doing this. Fuel will be a huge concern. Do a search here on NOS.
Old Nov 4, 2001 | 04:13 PM
Chief Knucklehead
Yes, you can use nitrous, but I'd highly recommend going with a wet shot where you get extra fuel pumped in with it so you don't run lean.
Old Nov 4, 2001 | 05:19 PM
Ryde _Or_Die's Avatar
MY exhaust is this || far from being done, and after that I am getting a wet 50 shot of NOS. I was thinkin about adding a S/C in the future(prolly 6 months or year from now). I would prolly find a way to set up an IC though. What kind of HP would you think I would get froma 7 in S/C, "true-dual" exhaust & a 50 wet shot of NOS? Think I could get in the 12s? A better question would be, do you think the car would be 12s material? Thanks alot.
Old Nov 4, 2001 | 05:56 PM
Chief Knucklehead
You can easily get into the 12s with a sc and a 50-shot of nitrous. The question is, can you afford to set it up correctly/reliably? With my setup (stock sc, no IC, K&N, header, high flow cat, and catback, RP fuel pump and 550cc/min sec. inj.) I dyno'd 210rwhp. Upgrade the sc from 10 to 17psi, upgrade fuel supply and ecu, add an IC and the 50-shot and you'll be flying.
Old Nov 4, 2001 | 07:26 PM
Where can I get a wet shot nitrous kit for my car and also, what fuel pump should I use with the supercharger and nitrous? Thanks
Old Nov 4, 2001 | 08:18 PM
Chief Knucklehead
Check out Nitrous Oxide Systems which is now owned by Holley. You're going to want to talk to the folks at Atkins about their fuel pump recommendation. (Remember, their sc uses a Holley carb while my Paxton setup uses the factory fuel injection.)
Don't want to seem like I'm blowing you off, but I'm not an expert on NOS, so I'd rather not give you advice that could blow your motor. The best thing I could say is to talk to Atkins, Holley and search the board for as much info as you can. Good luck!
Josh83rx7
Sep 15, 2015 10:23 AM
