craaaazzy's Widebody REW project
Old 03-03-17, 12:48 AM
  #426
RGHTBrainDesign's Avatar
Why not use expandable sleeving and heatshrink the ends? This is some amateur ****...
Old 03-03-17, 06:10 AM
  #427
Slowly but surely
craaaazzy's Avatar
Am using heat shrink where I solder the connection as mentioned. This is only temporary...the goal is to get the car running asap. I will then tackle the wiring later on and remove unnecessary wiring...the whole engine harness is still in tact even though I removed the rats nest, etc. I do like the expandable sleeving and thought I may use it later when I rewire but not really feasible unless u start fresh with no connectors and such. Don't worry, it will get done, just not at this moment.
Old 03-06-17, 09:31 AM
  #428
Slowly but surely
craaaazzy's Avatar
i had to add 2 more wires to my harness so decided to take sirlaughsalot's advice and use expandable sleeving. i will say, this sleeving is pretty darn cool and much easier than wrapping it up with tape (although i wouldn't say using tape is "amateur ****" as that's how mazda did it from the factory...it's definitely an improved way of doing it though).
Old 03-06-17, 10:58 AM
  #429
#garageguybuild
estevan62274's Avatar
Nice bro!
Hope to see her at Deals Gap
Old 03-06-17, 01:18 PM
  #430
Slowly but surely
craaaazzy's Avatar
Originally Posted by estevan62274
Nice bro!
Hope to she her at Deals Gap
thanks steven. i hope it will be done by then.
so i hear u picked up that sweet rx4. i'm sure that thing is a beauty in person!
Old 03-06-17, 01:40 PM
  #431
#garageguybuild
Yes sir, thx, Im also hoping to have it ready for dgrr.... but not enough fun car time lately
Old 03-06-17, 03:46 PM
  #432
**** yea! Great work!
Old 03-08-17, 11:54 AM
  #433
Slowly but surely
craaaazzy's Avatar
my father dropped by the house today so used his help to get the hood on. everything fits perfectly and i have about 1/2" clearance between the intercooler pipe and the hood. had to get creative and use my kid's playdoh to measure that =)
and my list:
-figure something out as a coolant tank
-bleed clutch
-bleed brakes
-install front seat
-install stock O2 sensor as well as wideband sensor
-WIRING <-this is the scary one (PFC, alternator, fans, fuel pump, MAP sensor, etc)
-tune PFC
i removed the optional items for now
Old 03-08-17, 08:53 PM
  #434
tool and die guy's Avatar
Stay the course.. creating a real masterpiece there.
Old 03-09-17, 05:15 AM
  #435
You wanna do what?????
Frankenmazda's Avatar
Looking good
Almost there. Can't wait to see what kind of power numbers you get.
Old 03-09-17, 01:39 PM
  #436
Rx7fb spirit r's Avatar
You have to adjust the mismatching. Open the screw underneath to correct or do some grinding for perfect fitting.
Hot built BTW! 👍💗
Old 03-09-17, 01:57 PM
  #437
Slowly but surely
craaaazzy's Avatar
Hot built BTW! ����
thanks. that's because of widebody fenders. they are not perfect unfortunately. thanks for pointing out the imperfection! lol, j/k
Old 03-13-17, 10:00 AM
  #438
Slowly but surely
craaaazzy's Avatar
i moved the MAP sensor to the driver's side firewall and redid the wiring for since it would be connected to the same #1 connector on the PFC. the one thing i don't like about this expandable sleeving is that you can't insert wires in existing sleeving (say in the middle of it). i ended up getting 1/8" sleeving this time from Fry's (which btw, is a lot nicer than the 1/4" sleeving I got from Amazon so if anyone is looking to use this expandable sleeving, get it from Fry's) and just running it parallel to the other wires.
Old 03-13-17, 11:34 PM
  #439
WireCare.com is where I get all of my expandable sleeving from. Currently I have a stockpile of Flexo PPS which I think is acceptable for almost all of my engine bay needs.
Old 03-14-17, 07:20 AM
  #440
Slowly but surely
craaaazzy's Avatar
thanks for the link! I'll keep them in mind when I redo my harness.
Old 03-19-17, 05:45 PM
  #441
Slowly but surely
craaaazzy's Avatar
Worked on mounting the PFC. Used existing bracket for the GSL-SE Ecu and added an aluminum plate to it for PFC. Then a small bracket to hold it in place.
Old 03-20-17, 04:04 PM
  #442
#garageguybuild
Looks good bro, I did something similar for my turbo FB back when I had the Haltech E6X for it.
DGRR is right around the corner, looks like you're on track to make it
Old 03-20-17, 06:04 PM
  #443
Must be like cramming for a mid term.. stay with it Fred!!! Yours will be a highlight at the show if you make it. I'm pulling for you. 36 days to go
Old 03-21-17, 06:23 AM
  #444
Slowly but surely
craaaazzy's Avatar
Slowly but surely.
Old 03-27-17, 09:31 AM
  #445
Slowly but surely
craaaazzy's Avatar
i believe i'm done wiring inside the car so put things back together. no pics without the carpet cause it's just wiring. but you can see the 2 relays i set up for the fans. still need to run power for the fans but that's in the engine bay.
i do need to build some sort of bracket for the commander though.
Old 03-29-17, 12:40 PM
  #446
Slowly but surely
craaaazzy's Avatar
wiring is now complete for the most part. took the time during lunch to wire in my electric fans. verified that they are sucking and not blowing. i need to crimp new connectors on my fuel pump wiring and that should be the end of wiring for now.
and my list again:
-bleed clutch
-bleed brakes
-install front seat
-WIRING (fuel pump)
-tune PFC
Old 03-29-17, 02:06 PM
  #447
Slowly but surely
craaaazzy's Avatar
so this is worth a laugh at my expense...
i was trying to figure out my fuse box and make sure i know what each fuse did (so i can document and store it in the glovebox). got most figured out but had issues with the fuses for the headlights and the retractors. headlights just wouldn't come on and pulling each fuse stopped the retractors from working as well. went inside, looked at the wiring diagram, everything looked good. go back to the garage and try the headlights again but this time, i walked to the front of the car...well guess what, no headlights installed. one of those "doh" moments.
Old 03-29-17, 04:55 PM
  #448
thats a good one!! Ha ha!! It happens. Kind of like the time my buddy Kenny was changing the oil in his car. He poured one, then two, then three, the fourth and final in. As he pulled the dipstick we noticed a rapidly forming puddle creeping out around the car.. we were laughing so hard at him as he's standing in a 1/2" of oil with a stunned look in his eye saying, it's not registering on the dipstick!!! Wtf you guys laugh at?? He stepped back two steps and nearly pissed himself laughing with us as he saw the puddle.
Old 03-29-17, 04:56 PM
  #449
Oh yeah.. he forgot to put the drain screw back in..
Old 04-02-17, 08:32 PM
  #450
Slowly but surely
craaaazzy's Avatar
luckily i did not make such a mess...but i have yet to put in fluids, so who knows...lol
fuel pump wiring completed. decided to ground directly to the body instead of relying on old wiring.
noticed i had forgotten to provide power to the injectors so had to run another wire on the passenger side of the engine bay. i did notice the FSM is incorrect...the injectors are powered by the .5sq fusible link (same one powering the coils/igniters), not the .3sq one. i verified this using my multimeter. i pulled it from the B-32 connector on the GLS-SE harness (the yellow/whitish connector on the bottom of this pic.
and my list again:
-bleed clutch
-bleed brakes
-install front seat
-tune PFC
Quick Reply: craaaazzy's Widebody REW project
