Haltech Ps1000 wiring questions.. sorry
Old Dec 26, 2016 | 12:24 PM
  #51
FührerTüner's Avatar
Penis Healthy
Originally Posted by R.O.D
Saw somewhere that the ECU needed to read kpa and not psi in order to spark?? Or did I read that wrong?
Swapped the wires and still no go
The kpa shouldnt not let it start.
How do you know youre not getting spark? With the ECU powered on, check youre receiving 12v on all the coil power inputs.
Old Dec 26, 2016 | 12:30 PM
  #52
R.O.D's Avatar
Forward, Always
OK, good to know. I was skimming over some posts and read about a "gotcha" referring to the kpa
I pulled a wire off a spark plug and stuck a screwdriver in it and put it near a ground, saw nothing. Didn't even hear a spark pop from either the lead or trail.
I went back through ecu main set up and fixed some minor issues. Trigger angle was off 5°
For trigger type, I need to be using multitooth 24 and 2 right? Couldn't find anything that said different.
Old Dec 26, 2016 | 12:32 PM
  #53
Penis Healthy
FC and Stock Coils
Trigger Angle 65
Tooth Offset 11
Spark Mode Distributor
Constant Charge
Falling Edge
4.5mS
Internal Reluctor
Trigger Edge Falling
Home Edge Falling
Trigger/Home Filter 1
Trigger Gain 2-3
Home Gain 2-3
Trigger angle should not cause a no spark issue. It will just be out of time. If you have power to the coils and your Ignition wires are all hooked up correctly, id check the CAS wiring and all grounds.
Old Dec 26, 2016 | 12:44 PM
  #54
R.O.D's Avatar
Forward, Always
I'll check grounds. CAS SHOULD be correct, the harness came terminated.
Still wondering what the trigger type needs to be. I've seen that list a few times and used it to clean up the main setup. But there's 3 options for rotary type. Multitooth 24 and 2, rotary 2/3 pulse, rotary 2/3 pulse no home, and rx8. Pretty sure I'm not using rx8 though lol. The list doesn't say anything as far as I can tell what the trigger type needs to be.
Old Dec 26, 2016 | 01:16 PM
  #55
Penis Healthy
Multitooth
Old Dec 28, 2016 | 03:57 PM
  #56
R.O.D's Avatar
Forward, Always
Finally got a good multimeter..
Is it possible the stock coils fried with red and yellow/black being switched?
Looking to see what the cranking volts "should" be.
Old Dec 28, 2016 | 04:50 PM
  #57
R.O.D's Avatar
Forward, Always
Trigger counter is working
leading red wire reads 2.04v key on and 82ish..V cranking.
Yellow/black gets nothing key on or cranking.
-_-
I think I found the problem...
My friggin flying lead is wired upside-down.. brb
Rewired. Proper color to color. Still no spark though..
Old Dec 29, 2016 | 08:18 AM
  #58
C. Ludwig's Avatar
www.lms-efi.com
Don't worry about spark yet. Log "triggers since last home" while cranking. That value should be 12 at all times with the engine turning on a stock CAS or FD crank wheel. RPM should also be 250-350 while cranking. Log those and let us know what you get.
Old Dec 30, 2016 | 01:18 PM
  #59
R.O.D's Avatar
Forward, Always
Trigger per home is 12
cranking rpm was a little low but I blame that on 11.4v at the battery.
Old Dec 30, 2016 | 03:33 PM
  #60
C. Ludwig's Avatar
www.lms-efi.com
Chcekc the ignition fuse. If you don't have battery voltage at the coils, you won't get spark. If the fuse is good, do a continuity test between the relay and the coils.
Old Dec 30, 2016 | 08:04 PM
  #61
R.O.D's Avatar
Forward, Always
Leading red wire AT coil reads 11.39v key on
Well I checked fuses, then checked relay.
Pulled relay off with power on, it clicked open
Put it back on clicked closed. If I put it all the way like it was I'd here another click?? Hmmm..
So I pulled it off again and slid it on just enough to click closed. Had leading harness disconnected trying to get readings key on and cranking.
While cranking it tried to start! ^_^! I cheeped like a child. Not even lying lol. Hooked leading back up and tried again. I was hard to start, I think from sitting for so long. But finally fired and ran for a minute on its own before dying.
Tried again, but I think the battery is too tired. Got it on the charger now. Gonna see here shortly.
It may be because the battery was low. But it seemed like the timing was too advanced. Idk. We'll see on a fresh battery.
Old Dec 31, 2016 | 06:24 AM
  #62
C. Ludwig's Avatar
www.lms-efi.com
Have you synched the timing? Need to do that before you try to start it.
Old Dec 31, 2016 | 02:11 PM
  #63
R.O.D's Avatar
Forward, Always
Well it does matter now. Was running great. Everything was spec. Went to get gas. BABYING it to the shoppette. Put a little premix in the tank just to be safe. I'm talking maybe 2oz. Went to leave, got in the gas just a bit. Just to get up to speed. Nothing crazy or excessive. Let off the gas BOV choo-chood, and the oil sprayed everywhere. Killed it and pulled off immediately to save the engine. Figured a oil line slipped or something. NOPE. Front iron cracked right at the turbo oil feed banjo. I'm sooo dang mad right now. Fresh rebuild. Maybe 500 miles. To ****. Really want to sell this thing now. Ten years down the damn drain. So mad!!!
Thanks everyone for the help. Ran great for 20 mins.
Old Jan 2, 2017 | 01:03 PM
  #64
Penis Healthy
Sounds like you detonated it. Sorry to hear it. Probably the last thing you wanna hear, but in the future, it's best to stay in vacuum until you have a tune. The haltech base map is only good enough to get the car started.
You're still not that far from completing the project. I know it's discouraging, but you should just keep on truckin.
Best of luck.
Old Jan 3, 2017 | 01:04 AM
  #65
R.O.D's Avatar
Forward, Always
Ya that's what I'm thinking. Friggin sucks though.
Stupid parts is. I had PLANNED on running n/a and for whatever reason, probably over excitement I didn't. Live and learn lol.
ugh. Another fail is just hard to swallow. I was looking forward to getting back to work after alot of hospital visits this year riding in the Rex.
IF all components minus the front iron are still in spec, is it possible a rebuild could be done with the existing gaskets being it has less than 500 miles on it and just replace the front iron? This purely hypothetical. Cause I'm sure there's alot that's not happy anymore.
Old Jan 3, 2017 | 03:34 AM
  #66
C. Ludwig's Avatar
www.lms-efi.com
Guessing you didn't synch the timing like I suggested in post #62?
Old Jan 3, 2017 | 11:08 AM
  #67
Penis Healthy
Youre gonna have to pull the engine for sure. Someone correct me if im wrong, but you should be able to just pull the front iron, replace with one in spec, and retorque.
Old Jan 3, 2017 | 08:37 PM
  #68
R.O.D's Avatar
Forward, Always
That's what I'm hoping for. I'm gonna call Jesse Prather, my builder and see what he thinks. He's my nearest go-to expert. Fingers crossed
Old Jan 3, 2017 | 10:06 PM
  #69
Penis Healthy
Good luck
