help identify what i broke and a new no start issue
Old Oct 3, 2016 | 05:43 AM
kensin's Avatar
Put it in the microwave!
so today as i was driving home i guess i press the clutch a little too hard and i heard somthing snap/broke and it broke to pieces
after i parked the car it wont start again , and i had no previous problem starting once so ever. can this be related ? thanks guys !
no crank at all but every thing else works.
Old Oct 3, 2016 | 07:01 AM
Barry Bordes's Avatar
"Elusive, not deceptive!”
Get a Wilkie button from the hardware store and insert it into the clutch peddle tab that depresses the safety switch for starting.
Barry
Old Oct 3, 2016 | 07:13 AM
kensin's Avatar
YES ! barry thanks for the headsup. how ever I found the problem just about 30 minutes ago I'm going to upload a picture for others that might have the same problem but don't know where to look
Old Oct 3, 2016 | 07:21 AM
kensin's Avatar
so i figured out what the problem was .
the red circle there is a rubber stopper for the clutch pedal once its pressed, it cracks and breaks as it ages . if it dose break it'll break the plastic button that's inside the green circle. when both breaks you experience a no start problem. just one of the many thing that could be your fix on click click *5000 click no start issue
Old Oct 3, 2016 | 08:19 AM
If the rubber plug in the green circled area breaks, you won't get a click at all. Your clutch switch won't work properly, so you'll turn the key forward and nothing will happen--- no click. This is getting more and more common as these cars age. One fix in a pinch is a short bolt and a nut.
Old Oct 3, 2016 | 08:20 AM
kensin's Avatar
i just used a screw driver to press against the rod and turning the key. (for now lol )
Old Oct 5, 2016 | 02:57 PM
IRPerformance's Avatar
Sponsor
46584-S0100
Its a Nissan part number that directly replaces the stock rubber bumper
Old Oct 6, 2016 | 04:19 PM
jza80's Avatar
Originally Posted by IRPerformance
46584-S0100
Thank you, sir!
rx7fan5645
9
Sep 28, 2016 04:27 PM
Ronnie1980
Introduce yourself
Sep 20, 2016 01:25 AM
eslai
Sep 16, 2016 10:05 PM
