wedge collar snap ring
Old Sep 24, 2016 | 02:44 PM
teamafx's Avatar
engine back in car, snap ring is seated in its groove yet when I go to press it in with the clutch fork the snap ring slides out of the groove and won't slide into the pressure plate. any ideas or do I have to pull the trans?
Old Sep 25, 2016 | 08:48 AM
teamafx's Avatar
so no help. I guess I pull the trans
Old Sep 26, 2016 | 09:40 AM
Gilgamesh's Avatar
snap ring goes on the pressure plate first. then once the trans in installed you push the throw out bearing into the snap ring and it locks in place.
Old Sep 26, 2016 | 11:08 AM
IRPerformance's Avatar
Sponsor
Its either bent or damaged. Unfortunately trans will have to come out.
Old Sep 26, 2016 | 12:53 PM
FourtyOunce's Avatar
I agree with the Huk on this one. If the ring is bent or warped, I would suggest to get a new one.
Old Sep 30, 2016 | 06:20 AM
Banzai-Racing's Avatar
Rotary Specialists
We install the ACT monoloc wedge collar in all aftermarket clutches to avoid this issue.
ACT HD Clutch Kit (93+RX-7)
85RX7mtv
Sep 11, 2016 10:35 AM
10thaepat
15
Sep 3, 2016 10:28 AM
Trinityevo13
Aug 30, 2016 03:45 PM
MaroonLynx
Aug 30, 2016 08:33 AM
12abridgeport
Aug 29, 2016 12:50 PM
