Anybody want to guess a dyno figure?
Old Sep 18, 2016 | 07:37 PM
peejay's Avatar
Old [Sch|F]ool
After having the engine in my car for four years this month, I finally had an opportunity to dyno it. Anybody want to hazard a guess as to what the RWHP numbers were?
Salient points:
Bridge ported 4-port 13B, 12A end and GSL-SE center housings, ported to Mazda Group A spec ports on the exhausts, ends, and as close as I could get with the metal available on the center
Racing Beat street port exhaust system and Holley intake manifold, Holley 750 carb, 4" $30 parts-store cone air filter on a blower carb hat
Runs made in 3rd gear, with a 4.78 final, on a Mustang dyno. Torque figure was 130. (Peak torque was double, something like 4400rpm and again at over 7k)
Peak HP was at 8900, then the soft rev limiter starts dumping all kinds of fuel.
Contest ends when my friend who was taking video posts it online, so maybe a day or two?
Old Sep 18, 2016 | 08:18 PM
Andre The Giant's Avatar
I'll guess 196.5 hp
Old Sep 19, 2016 | 12:17 PM
Doc Holiday's Avatar
Needs more cow bell
130 at 8900 = 220
you made 260ft lbs? did I read that right?
Old Sep 19, 2016 | 12:18 PM
peejay's Avatar
Old [Sch|F]ool
No, two torque peaks. Peaked early and then came back up again. Probably didn't drop more than 5% between peaks, though.
I think, but can't tell, that the 4400rpm figure was the true peak. The ports are small and the exhaust runners are long
Old Sep 19, 2016 | 02:11 PM
Kenku's Avatar
spoon!
Hmm, I'm going to go for 203hp.
Old Sep 19, 2016 | 06:05 PM
peejay's Avatar
Old [Sch|F]ool
Bear in mind that the car was quieter than the RB26-engined 240SX (~260whp), the very clean MkIII Supra (~440hp when it got a clean pull, had breakup issues sadly), and the 6.4l Challenger that got a bazillion pulls because of nitrous issues they were trying to debug.
Old Sep 19, 2016 | 07:40 PM
i also say 220hp. that is impressive! and making 90% of peak torque for more than 3,000rpm is also impressive
Old Sep 19, 2016 | 08:05 PM
lastphaseofthis's Avatar
My job is to blow **** up
imma go high 285.
Old Sep 19, 2016 | 08:09 PM
peejay's Avatar
Old [Sch|F]ool
Originally Posted by lastphaseofthis
imma go high 285.
LOL! I wish!
Old Sep 20, 2016 | 06:05 AM
Buggy's Avatar
I've Been Wankeled!
Sounds very similar to my rx4 and I know it made 203 whp so I'm guessing low 200whp range.
Old Oct 9, 2016 | 05:00 PM
218hp
Old Oct 9, 2016 | 06:51 PM
peejay's Avatar
Old [Sch|F]ool
I'm still waiting for the dyno video to be posted...
Old Oct 18, 2016 | 09:28 PM
t-von's Avatar
Rotor Head Extreme
210whp
Old Oct 21, 2016 | 02:43 PM
KNONFS's Avatar
B O R I C U A
Uploading a 1080p video from a dial up connection?
Come on man, tell us!
Old Oct 21, 2016 | 04:47 PM
peejay's Avatar
Old [Sch|F]ool
Yeah, I'm giving up, it's on a smartphone so he'd probably just post it on Facebook instead of on the internet...
The answer is: 208whp:
Engine feels "stronger" than the engines I've had on that recorded more torque at the wheels on a Dynojet, so who knows? By the time I can get this engine on a Dynojet again, it will be running through a Ford 9" instead of a Mazda 7" so that won't be good for direct comparison.
FWIW - This is still the same engine I built in 2012: https://www.rx7club.com/naturally-as...s-not-1003287/
Old Oct 21, 2016 | 06:48 PM
Kenku's Avatar
spoon!
Man, that torque "curve".
Old Oct 21, 2016 | 06:58 PM
peejay's Avatar
Old [Sch|F]ool
Yeah, I absolutely love it. It feels so linear, almost hydraulic.
Old Oct 26, 2016 | 11:58 PM
t-von's Avatar
Rotor Head Extreme
So what's my prize for only being 2whp off?
Old Oct 27, 2016 | 07:21 PM
peejay's Avatar
Old [Sch|F]ool
Old Oct 28, 2016 | 11:28 AM
+1, it is of course because bridge ports make no torque until eleventy billion rpms
Old Nov 1, 2016 | 06:28 AM
j_tso's Avatar
Peejay, is this how big the Group A port goes? The starting point is an original '79 12A port and I used the measurements from homologation drawings. I'm just wondering why the eyebrow doesn't extend the whole length of the port.
Old Nov 1, 2016 | 07:11 AM
KNONFS's Avatar
B O R I C U A
Good job
Have you considered (or ran) a full PP? Reading j9fd3s experiences with a PP, makes me want to give it a try
Old Nov 1, 2016 | 05:01 PM
My guess is you choose if you want the rotor to close the main port last or the bridge port last or close both together (look at shape of rotor on closing line).
If you close the main port last you do have a larger air column and a more direct push into the compression stroke.
The bridge is a branched off tributary on this baby bridge style port.
If you close the main port first then the airflow has a more tortured route into the compression stroke through the bridge.
Ideally, I would think you would want to close the "snout" (area near the oil seal track) of the main port last (reverse scissor port).
You might be able to get away with this on a bridge since you do not open the main port earlier, so both side seals ride on the bridge or it still might eat your side seals- IDK.
Not sure why the port you pictured is so extremely scissored.
I would think something like this would be more ideal-
Old Nov 1, 2016 | 07:35 PM
j_tso's Avatar
I was guesstimated it off this drawing from the FISA homologation book (it's on foxed.ca):
I wasn't sure about the angle or where the eyebrow started. The drawings are for scrutineers so I referenced the measurements and didn't take them for templates.
Old Nov 1, 2016 | 08:12 PM
peejay's Avatar
Old [Sch|F]ool
That is the port that I used, actually. I took the scan, printed it out, measured the print vs. the dimensions called out, then altered the print so it would print "1:1". I do remember that the bridge width is not drawn to scale, so you can't make a "template" from this drawing but it is still quite useful.
If you accept that the inner curve does not move relative to stock, and that the opening line has to have a curve following the corner seal track, its placement on the side housing becomes obvious. Actually it appears that the main port's opening line stays stock relative to 12A. It also appears that this Group A main port opening is identical to a Racing Beat street port template, assuming that my Turbo II engine was street ported to an RB template. It matched exactly.
