Haltech How does this Ignition and Split map look?
Old May 3, 2016 | 03:53 PM
FührerTüner's Avatar
Penis Healthy
Do these look ok?
Old May 3, 2016 | 07:49 PM
C. Ludwig's Avatar
www.lms-efi.com
Not going to run the primary ignition in vacuum?
Old May 4, 2016 | 06:26 AM
Penis Healthy
Yeah, that was supposed to be absolute pressure...
Fixed.
Look ok?
Old May 4, 2016 | 08:46 PM
Penis Healthy
Bump
Old May 6, 2016 | 03:49 AM
C. Ludwig's Avatar
www.lms-efi.com
Looks like a bit much under high vacuum and a bit conservative under boost on the primary map. The split map is jacked, IMO. Here's what I use as a base maps.
Old May 6, 2016 | 07:59 AM
Penis Healthy
Awesome, Thankyou!
How did you get 20 columns for load, and 22 rows for rpm? The software seems to only let me have 16?
Old May 6, 2016 | 03:33 PM
C. Ludwig's Avatar
www.lms-efi.com
1500/2500
Old May 6, 2016 | 10:19 PM
Penis Healthy
Wow what bullshit...
Old May 7, 2016 | 04:32 AM
C. Ludwig's Avatar
www.lms-efi.com
Why? It's always been that way. Sprint was 16x16, Sport 32x32. Elite 750 is 16x16, 1500/2500 32x32. Not like they hide it from you. It's on the spec sheet.
Old May 7, 2016 | 08:10 AM
Penis Healthy
I guess i just didn't know. I always thought the difference in the ECU's was inputs and outputs and hard features. I would think something like a table wouldn't be any different between ECU's considering it doesn't cost any money to implement it. I guess i was wrong.
GoatFaceKiller
Test Area 51
Feb 11, 2016 10:52 PM
Grifkylian
NE RX-7 Forum
Jul 10, 2012 05:42 PM
Grifkylian
Race Techniques
