hacked wiring - steering column
Old May 10, 2011 | 08:51 AM
distr0's Avatar
Hey, hoping someone might have an idea what this wiring is doing here
one of the wires going along the left side of the steering column is tapped here
the red wire coming from there passes to the other side of the steering column into this relay
from there, the orange goes into this white onnector into the yellow/black stock relay
and green goes to another relay
on there the one black looks like its supposed to be a ground, the other black loops between 2 terminals on the relay, and the yellow goes to this sensor on the gas pedal (full throttle switch?)
if it matters, the car was an auto n/a s4, converting to s4 t2 everything
any ideas?
Old May 10, 2011 | 11:11 AM
jakkyl's Avatar
That black/white wire coming from the black relay is where you would wire a fuel pump cut off. Not sure what that other wire is though. Maybe it's related
Old May 10, 2011 | 09:07 PM
CS13B's Avatar
From the Roots Up!
Nevermind
Old May 11, 2011 | 06:44 AM
HAILERS2's Avatar
Black/Green at the ignition switch on a Automatic car is the Start wire.
The Yellow/Black wire in the Starter Cut Relay is switched power that is there anytime the key is ON.
I''m not familiar with the switch on the throttle pedal. Auto related item.
Old May 12, 2011 | 03:09 PM
distr0's Avatar
thanks for the infos, good starting point anyways
guess i'll have to dig into the wiring diagrams though
Old May 12, 2011 | 03:45 PM
HAILERS2's Avatar
I made a mistake. You said that the brown wire went into the yellow/black relay and I interpreted that as yellow/black wire.
So where the brown wire goes to the white connector of yellow/black relay..................my queston is, is that brown wire sharing a socket in the white connector with another wire or is it all alone in the white connector?
Old May 12, 2011 | 09:09 PM
distr0's Avatar
The brown wire has been repinned into the relay replacing whatever stock wire was there, no sharing
Could it be a flood clear system? Tied to ignition switch and full throttle switch... Does that black/yellow relay have anything to do with fuel?
Old May 12, 2011 | 10:56 PM
misterstyx69's Avatar
Retired Moderator, RIP
IF it is,I think it would SUCK!
..as you may be able to clear the Fuel at WOT,..BUT what about when you Punch the Throttle???..you get Fuel Cut off???.
I wanna find out more on that thing,..( why do people tear into stuff without knowin ..)
By the way that Black and Yellow connectored Relay IS a Fuel Pump Relay, on an S4.located under the dash,steering column area.right knee...(lol!)
Old May 12, 2011 | 11:44 PM
distr0's Avatar
almost certain now that it is a flood clear. its wired in to the START wire in the steering column AND the full throttle switch! it only kills fuel if you're cranking and have the pedal to the floor! lols
Old May 13, 2011 | 06:01 AM
HAILERS2's Avatar
Cool. Clears floods like a stk series five does.
Old May 13, 2011 | 12:57 PM
distr0's Avatar
here's the brown wire going in to the relay connector
any ideas what these blue/greens are? they're snipped right at my thumb there
Old May 13, 2011 | 03:48 PM
HAILERS2's Avatar
A normal plug for the Circuit Opening Relay would look like the jpg attached. That view is looking into the wire side of the plug.
The blue wires in your hand.................they would be considered blue wires. The green hash mark means zippity.
When you look at the jpg attached you see a L/R or Blue/Red wire in the corner of the plug. That wire leaves the relay base and goes to the rear of the car to feed the fuel pump.
I don't understand the blue wires in your hand. You might remove the friction tape and see what is under there. Is it two wires spliced together or what. Both deadended under there? or what?
The blue/red wire would have a jacket colored blue with a solid red stripe running its length. This jpg is out of a 88 wiring diagram but I have a 86-87 FSM with wiring and I'm pretty sure it's the same. Have not looked but I"m fairly sure.
Old May 23, 2011 | 08:39 PM
distr0's Avatar
fyi if anyone is interested - i removed the system (mostly because megasquirt will have flood clear functions anyways, and i don't want to have to worry about iffy wiring)
here's a pic of the whole setup. the blue/green actually must have been plugged into the gold relay, and that's what triggered the fuel pump
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
Kruel13
24
Sep 16, 2015 09:08 AM
breakfast
Sep 1, 2015 11:02 PM
