Carb questions
Old Sep 1, 2010 | 07:15 AM
JoeNoble's Avatar
Almost not rotarded
Carb questions
so yesterday I cleaned most of the crap off the carb and tore it down. I also removed the "heat shield" from the spacer and got the gasket off one side of it but I used a rotary tool and a sanding attachment and now theres a few spot that are uneven. can I just get it close to even and then use rtv high temp gasket sealer or is it ruined? also could i soak my carb in something like the product in this pic to get rid of the rest of the dirt?
hear are some pics of the spacer and carb disassembly.
Old Sep 1, 2010 | 09:01 AM
trochoid's Avatar
Old Fart Young at Heart
You fucked up. You never mess with the spacer plate. Toss the gaskets that look like they fit the spacer, and the spacer, in the trash. Always reuse the spacer just like it came off the carb. Time to find a good used spacer plate. Buy a gallon can of Berryman's carb cleaner. Once you have the carb broke down, it will fit in the can. Inside the gallon can is a strainer basket to catch all the small loose parts.
Old Sep 1, 2010 | 09:51 AM
JoeNoble's Avatar
Almost not rotarded
Lol the one I messed up was a spare so I'm still good but what's the best way to get gaskets off of the spacers?
Old Sep 1, 2010 | 10:06 AM
cshaw07's Avatar
I need a cheaper hobby...
i dont know, but if your read sterings carb rebuild article he even says:
"If you do need to remove the plate for cleaning, etc, do NOT try to remove the gasket. They are adhered to the plate."
http://www.sterlingmetalworks.com/re..._the_nikki.htm
Old Sep 1, 2010 | 10:38 AM
Oneiros's Avatar
if you have an early manifold with cross cut runners it might help cross cutting the spacer.
Old Sep 1, 2010 | 10:42 AM
DivinDriver's Avatar
1st-Class Engine Janitor
You don't.
They are not replaceable, you don't remove them.
You re-use the spacer as it is.
There aren't any replacements for the gaskets, because they're not 'gaskets.' They're a permanent part of the assembly.
Capice?
Old Sep 1, 2010 | 10:56 AM
JoeNoble's Avatar
Almost not rotarded
Gotcha thanks guys. Btw trimming off the "heat shield" doesn't hurt it right?
Old Sep 1, 2010 | 01:33 PM
Jeff20B's Avatar
Lapping = Fapping
Shouldn't hurt it. Go ahead. Just don't remove the gasket from this one, ok?
Old Sep 1, 2010 | 08:47 PM
JoeNoble's Avatar
Almost not rotarded
How do i get these out? i dont have a screw driver that wide nor do i think ive ever seen one.
Old Sep 2, 2010 | 12:19 AM
Jeff20B's Avatar
Lapping = Fapping
Those are seats for the needle/seats. Why do they need to come out? Do you have new ones to install? Are they super gummed up with varnish that you haven't been able to clean out? What I'm saying is they don't need to be removed. At least I've never bothered.
Old Sep 2, 2010 | 12:37 AM
rxtasy3's Avatar
ya know, whenever i run across a need for a tool i don't have it's just another reason to buy tools. but i think u'll find u can get it loose with what u have just using one of the slots. it's one of those "been there, done that" kinda situations.
Old Sep 2, 2010 | 07:32 AM
JoeNoble's Avatar
Almost not rotarded
Well the rebuild kit I have came with replacements but I'll just ahead and use the old ones they don't look too bad.
Old Sep 2, 2010 | 07:45 AM
Jibaro 12A's Avatar
searching...
I'd use the new ones if they were supplied in the kit. Get a helper, have them hold the airhorn assembly on top of a table very firmly. Get a butter knife, use the flat side of the blade . While you loosen them make sure to firmly have your hand placed on the knife so the blade doesnt tear that brass up.
Old Sep 2, 2010 | 10:35 AM
JoeNoble's Avatar
Almost not rotarded
K I'll give that a try after work. Btw I just looked in our comp and noticed that the 79 carb kit has a different part number than the 83 kit. Anybody know what the difference is?
Old Sep 2, 2010 | 12:12 PM
Jeff20B's Avatar
Lapping = Fapping
The 79 air horn gasket lacks holes for the altitude compensator plumbing, amoung other differences.
Old Sep 2, 2010 | 12:33 PM
JoeNoble's Avatar
Almost not rotarded
Can I over come the differences by creating needed holes and not putting un needed parts back on?
Old Sep 2, 2010 | 12:47 PM
cshaw07's Avatar
why didnt you just get a rebuild kit for an 83?
Old Sep 2, 2010 | 01:44 PM
Jibaro 12A's Avatar
searching...
Just get the right kit bro. Aint nothing worse than half-assing a job and having to go back in to rectify your mistakes. If your near a Autozone get the GP Sorenson kit 96-462 it has all the gaskets for all the 79-85 models.
Old Sep 2, 2010 | 05:23 PM
JoeNoble's Avatar
Almost not rotarded
Yeah I work at az actually but the kit came with my car when bought it and I'm not sure which one it is to be honest.
Old Sep 3, 2010 | 07:08 AM
cshaw07's Avatar
i think a new kit is like $20 plus you probably get a discount anyway.
Old Sep 3, 2010 | 10:25 AM
BandDButton's Avatar
Darrell B
be sure to get the kit that comes with new check *****. Be careful not to loose the two weights that are also in the carb when you take it appart, they can't be replaced. Also, if you read Sterlings site he tells you to burnish the edges/corners of the new needle valves. Be sure that you do this so you don't have on stick open, or closed, and pump gas everywhere all over the top of the motor, or cause flooding.
Old Sep 4, 2010 | 12:24 AM
Oneiros's Avatar
+1 for the burnishing trick, it will save you a lot of hassle.
as for the needle seats, I bought a large screwdriver and ground down the blade so that it would fit. alternatively some jaw grip pliers can remove them and then like suggested use a butter knife on its side to tighten them. just be sure they are very tight, as I've had a few come loose.
Old Sep 4, 2010 | 01:47 PM
JoeNoble's Avatar
Almost not rotarded
What part exactly am I supposed to burish? Got a pic of it?
Old Sep 4, 2010 | 02:36 PM
Jibaro 12A's Avatar
searching...
The part you burnish is the needle bro, it has a rubberized gray tip. Forget asking for pics you work at Autozone you should know this! LOL! hint: they will fall out as soon as you remove these guys.
Old Sep 4, 2010 | 02:56 PM
JoeNoble's Avatar
Almost not rotarded
Yes I work at az however it's my third week and this is my first carb rebuild. So I need to burnish the tips of the needles that go down inside there? Correct?
