Oil Pressure and Water Temp Gauge Help
Old Apr 24, 2002 | 11:03 PM
arie1955's Avatar
I just got the new Blitz gauges for the Water Temp and Oil Pressure. I want to install them myself, and i can do it cause have done it on other cars. However, would like to know the best place to mount both gauges inside the engine bay, i just wanna be sure of my initial thoughts and confirm them, thank you.
Old Apr 24, 2002 | 11:22 PM
P'cola FD's Avatar
Hamado things my way!
You want to mount the gauges in the engine bay? I have mine on the A-pillar.
Old Apr 24, 2002 | 11:41 PM
Import Convert's Avatar
I've got oil press and water temp gauges (Autometer) too, but I have not yet installed them. I plan on replacing the stock oil press sending unit with the supplied Autometer one, but I'm not sure if the original gauge will work with that. I will be drilling a new hole in the thermostat housing for the water temp. I don't agree with that TB coolant line idea.
EDIT: You didn't actually mean you were mounting the gauges themselves in the engine bay did you?
Old Apr 24, 2002 | 11:58 PM
jspecracer7's Avatar
1JZ powered
Re: Oil Pressure and Water Temp Gauge Help
I hope you mean..."Where do I mount the SENSORS?"
The oil pressure, you can get a Greddy adapter that bolts on top of where the oil filter is, then use on of the lines out of it for the oil pressure.
The water temp. is easy. Simply get a water temp adapter that attaches to one of the radiator hoses. Cut the radiator hose to size using the adapter, put the water temp. sensor in it and presto!
...you have water temp.
Old Apr 25, 2002 | 05:04 AM
A-Spec's Avatar
here's the greddy ones that Jspecracer is referring to.
oil temp/pressure
water temp
Old Apr 25, 2002 | 06:22 AM
Oil/ water temp help
Hey everyone, I do not want to **** in anyone's cornflakes, but if you are able to somehow get the temp sensor into the block, it would be wayyyyyy better than in the hose. If the T-stat sticks closed, and they occasionaly do, the water will stop flowing, and the sensor won't know it. Scenario #2, if the belt breakes, or for some other strange reason the Water pump stops pumping, again no coolant flow, and no indication of impending doom. Just something to think about.
Jay
Old Apr 25, 2002 | 06:05 PM
arie1955's Avatar
I did mean sensors. I was looking into the Greddy Adapter, but no one knows what it is but me when i want to order it. Do you have a part # for it?. However, i am confused about the water temp sensor, and where to put it, its just a metal plug, and wondering where to put it.
Snoopy FD
Dec 8, 2015 01:45 PM
andyvideopro
Aug 20, 2015 10:55 AM
