New gasket...with every oil change?
Yeah, you probably should replace it each time. It is a crush washer, so it doesn't have the same physical properties after it has been installed once (ie- won't seal as well). I don't know the size, but the dealer has 'em for like a nickle appeace. On a side note, i didn't change mine a few times with no problems. But now I change it every time i drain the oil.
~Tom
~Tom
These types of valves have been used on aircraft for years, so I have no idea why automotive manufacturers have ignored this fantastic product. Oh well, maybe someday cars will come standard with this, as they have finally caught on to other good products like synthetic gear oil and SS exhaust.Thanks for the web link! I had lost contact with them after they moved from their California address. I gotta get some of these for my other vehicles!
Do we need those extra fittings/nipples too?
Trending Topics
I got this letter last week. I'm not sure how long the 10% discount is good for, but you may as well just include the discount code in your order just in case.
Dear Valued Customer,
Thanks for your interest in Fumoto Engine Oil Drain Valves. If you have already purchased one, we are confident you have enjoyed using it for quick, easy and clean oil changes.
YM International Co., authorized online retailer of Fumoto Engine Oil Drain Valves, wishes to provide you and your friends with a SPECIAL 10% DISCOUNT OFFER to thank you for supporting our business.
Using YM3 as a discount code, you and your friends will get 10% OFF when ordering at our online store: www.fumotovalve.com.
Thank you for your business and happy oil changing!
Yoshi Mizukami
GM YM International Co.
Yoshi Mizukami
From: Ft. Worth, Texas, USA, Earth, Solar System...
I use one from the local parts store... I think it's made by Fram (YUCK!) but it's 3 parts... a plug with a valve like the one in a car valvestem, a cap to keep dirt out, and a fitting with a hose. You just remove the cap (it's finger tight) and screw on the fitting with the hose (again with fingers) and it drains. Remove the hose/fitting and it stops. Put the dust cap back on, replace the filter, and fill. These are available at any parts store for about $12-$13 or so.
Brad
Brad
LunchboxSA22
37
Oct 26, 2015 10:53 AM
ncds_fc
Aug 15, 2015 10:06 AM
