How to remove pin stripes?
Old Apr 22, 2003 | 11:22 PM
adamlewis's Avatar
Back from teh deadly!
Anyone got any suggestions?
Old Apr 22, 2003 | 11:23 PM
ZachSpazz's Avatar
I wish I had a posse...
Goo-Gone and careful use of a razor-blade?
Old Apr 22, 2003 | 11:29 PM
adamlewis's Avatar
I dont know if I can hold my hand that steady
Old Apr 22, 2003 | 11:33 PM
nashman69g's Avatar
Boost Addict
there is some kind of wheel that you put onto a air drill and it supposed to take it right off....the problem is that it costs a lot of money for one...like around $100...that what this shop guy told me...don't know if any of this is true or not...the guy is a crackhead!!
Old Apr 22, 2003 | 11:41 PM
adamlewis's Avatar
lol
Just what I need...Advice from a crackhead.
Old Apr 23, 2003 | 01:34 AM
chris-reedtn's Avatar
you tried sand paper, it did the trick for me!
-Chris
Old Apr 23, 2003 | 05:20 AM
fingernails work wonders!!
Old Apr 23, 2003 | 05:38 AM
Bruce's Avatar
Use your fingernails(sometimes a razor blade if you going to have it painted) and a heat gun. You can find the heat gun in the hard wear store around a paint section, there used for wall paper.
Old Apr 23, 2003 | 11:14 AM
Turbonut's Avatar
If paint is good, I wouldn't use any abrasive material. Use combination heat gun/3m adhesive remover.
Old Apr 23, 2003 | 11:17 AM
Nick86's Avatar
Yup, still here
Call a body shop you trust and ask them.
While you're at it, ask them how much it would cost to have them do it - I'll bet it's cheaper than you think!
Old Apr 23, 2003 | 11:18 AM
skyypilot's Avatar
Heat gun, use it carefully, and finish the job with Goo-Gone..........
Old Apr 23, 2003 | 11:22 AM
donut's Avatar
use a pen cap cover its pretty sharp enough but yet dull it wont scratch the car up and itll help u take off the stickers. My friend used it and took off his stripes now his car looks great
Old Apr 23, 2003 | 11:44 AM
theonlygreat's Avatar
my friend who works at a detail shop uses a plastic razor blade and a heat gun. not sure where you get the plastic razor blade though. usually the paint needs to be buffed afterwards to get the fade let from the stripe to go away.
if you don't have a heat gun a blow dryer used in moderation will work. don't get the stripe too hot or it gets weak and you have to keep restarting. and if it's too cold it will break because it's still sticking to the car too well.
Old Apr 23, 2003 | 12:46 PM
banzaitoyota's Avatar
What Subscription?
The correct tool is a 3M Pinstripe removal wheel
Old Apr 23, 2003 | 12:52 PM
DC350's Avatar
Rotor Head
I agree with banzai. They are only around 17 dollars (Canadian) and you can get them at your local auto parts store. It screws into the end of the drill and its just a big eraser. takes the pinstriping off like no ones business
Old Apr 23, 2003 | 01:04 PM
What Subscription?
http://www.ketone.com/search_results...earch&iLevel=1
Old Apr 23, 2003 | 01:07 PM
What Subscription?
Here is a link for the wheel alone:
http://www.autotoolmart.com/cgi-bin/..._sresults.html
Old Apr 23, 2003 | 01:08 PM
Nick86's Avatar
Yup, still here
The wheels are less than $20.
Again, the adage about having the right tool for the job proves to be true!
Old Apr 23, 2003 | 03:37 PM
joevc's Avatar
You guys crack me up!
Advice out the A##.
Go to a sign shop and tell them you want to buy a "lil chisler'. Usually a pink plastic scraper. Every one should have one.
Heat gun idea alright but may @#$% up your clear or paint.
Take your time and all will work out.
The WHEALS are great but will eat the paint off.
Body shop idea is the best yet--or call a dealership ind ask them who "installs" their pintripes.
That guy will have the right tools and knowlrdge to not mess up your car.
Old Apr 23, 2003 | 04:55 PM
jaredcolletti's Avatar
Ive used that wheel alot, its cheap and its awsome. hold it at a 90 degree angle with the surface, like the picture shows. works killer
jared
risingsunroof82
Sep 7, 2015 01:11 PM
