need info in putting t2 trans and diff. in 86 n/a??
Old Feb 17, 2003 | 09:55 PM
RoToRrOcKeT19's Avatar
Question need info in putting t2 trans and diff. in 86 n/a??
hey wuz up, i got a a guestion, i have an 1986 mazda rx-7 and i would like to put a turbo 2 trans. and diff., now do u have to put a turbo 2 clutch and flywheel or just the clutch, and what other things do i need in order to do this swap, and do i have to do any cutting or custom stuff, thanx
Old Feb 17, 2003 | 11:50 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Ok, first let ME ask YOU... why? If you are planning on over 220 hp, ok I understand. Otherwise, it is heavier, more expensive, and it's a lot of work.
You have to do the whole drivetrain at once- you can't do the diff now and tranny later or vice-versa, unless you have a custom driveshaft made. So, essentially, it's all or nothing.
How to do the swap: (yes, I did this already.)
For the differential, I recommend you get the ENTIRE rear subframe assembly and swap it. I'm not going to go into detail as to how, it's simple... a LOT easier than trying to do it in pieces.
The transmission uses a different clutch, with a larger diameter. You will have to swap the clutch, pressure plate, flywheel, starter, and clutch slave cylinder. You will also have to make some longer wires for the wiring harness to the transmission (neutral switch, indicator for the "shift up" light, etc.) I'm not sure about the crossmember, I suggest using the TII one. I did, didn't even try the other one.
I also suggest getting both the front AND rear swaybar from the TII. They are heavier, and you don't want just a heavier rear bar- the car will oversteer if you do that.
No cutting or custom stuff, unless you call making 4 wire extensions using a crimp connector "custom stuff." It all bolts right in. The flywheel is a major PITA to swap though.
I suggest doing a search for more details, this gets rehashed on here frequently!
Old Feb 18, 2003 | 09:23 AM
damn sounds like a lot of work, well how can i make my car possie, and can the the normal transmission that i got handle alot of power even if i get it rebuild
Wicked93gs
Aug 23, 2015 10:14 AM
rx7jocke
Aug 15, 2015 03:36 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
