Venting BOV...
Old Sep 28, 2002 | 04:26 PM
Scrub's Avatar
bow leggin'
Venting BOV...
Alright. What side do i disconnect. The side going to the Y pipe or the side going to the intake. If im not mistaken it's the one going to the intake. But I thought there were 2 bov's stock. I could be wrong.
Old Sep 28, 2002 | 04:30 PM
crazyrx7's Avatar
Big Daddy!!!
If you are running sequentially then you have one blow off valve. And yes you do disconect it from the intake side. Make sure to block off that hole where the blow off valve hooked up to. If you are running non-sequential then you have two blow off valves (the other one becomes a blow off valve as well). If you vent both of them to atmosphere they will be pretty loud.
Old Sep 28, 2002 | 04:46 PM
JONSKI's Avatar
5yr member, joined 2001
If you don't want a whooshing sound between 0 and 4500rpm, then skip step #2.
Old Sep 28, 2002 | 05:15 PM
Scrub's Avatar
bow leggin'
okay thanks, I might just keep the stock ones attached untill i do some other mods. What do i use to block the holes with, if i do want to do that?
Old Sep 28, 2002 | 05:29 PM
RX7Elmo's Avatar
you can find rubber bumpers or vaccuum caps at almost any hardware or auto store. You can still vent both the CRV and the BOV if you are sequential.
Danny
Old Sep 28, 2002 | 06:29 PM
Where can I find step-by-step instructions for venting BOV to atmosphere? (or tips on what to use for a search)
Thanks
Old Sep 28, 2002 | 06:42 PM
skunks's Avatar
I'm a CF and poop smith
Another pic tutorial
These are great, keep them comming
Old Sep 28, 2002 | 07:37 PM
paw140's Avatar
Ummm.... Jonski's post, maybe?
Old Sep 28, 2002 | 07:52 PM
JONSKI's Avatar
I don't have it labeled, but if you look closely at the air box, I have a nipple plugged with a 20oz plastic coca-cola bottle cap. it's not air-tight, but it works well enough.
Old Sep 28, 2002 | 08:35 PM
Talek's Avatar
What worked well for me to cap the airbox hole was to keep the piece of rubber that is normally between the bov and the airbox on there, put a 20 oz cap over the end of the rubber where the bov connected, then use the clamp that was being used to hold the hose on the bov to help clamp down the cap. It's a tight fit, no leaks and it's stayed on so far (2 months or so).
Old Sep 29, 2002 | 01:05 AM
Scrub's Avatar
bow leggin'
If any of you play paintball, and have a Tank for there gun, the flexible plastic cover for the threads fit's perfectly and is air tight. At least thats what my friend said that did it. Just thought you might like to know. I may or may not try it, not sure yet.
Old Sep 29, 2002 | 02:22 AM
EviLPeNeviL's Avatar
Can't live without boost.
Will any harm come to the engine or any part of the engine bay if this air box hole isn't blocked off?
-Dan
Old Sep 29, 2002 | 10:00 AM
Scrub's Avatar
bow leggin'
I would rather be safe then sorry.
Old Sep 29, 2002 | 10:22 AM
JONSKI's Avatar
-Dan
If you leave those nipples unplugged, then you will be sucking in HOT, unfiltered engine compartment air. If you have an exhaust leak, then you will also be sucking in exhaust. With turbos, you want your air to be as cool and clean as possible. Hot intake air can even cause pinging and detonation while boosting.
Old Sep 29, 2002 | 03:14 PM
MazdaMike's Avatar
i used the coke cap also heh works like a charm
-Mike
Old Sep 29, 2002 | 09:09 PM
Sounds good to me. However the only valve that I have venting into the atmosphere is the stock BOV while the stock CRV is still connected into the air box, therefore I'll have only one hole to worry about. I will get to that ASAP.
So the best choice of plug comes from Coke bottles? What about the big black rubber stoppers that you can get from them hardware stores?
-Dan.
Old Sep 29, 2002 | 09:15 PM
ROTORROCKET's Avatar
A wine cork works perfect. Nice and snug...
Old Sep 29, 2002 | 09:21 PM
Not to change the subject, But does anyone have an Apexi Twin Chamber BOV? and what does it sound like??? Does it whistle like the HKS SSQV? forgive my intrusion, I am only a newbie.
Old Sep 29, 2002 | 10:24 PM
Hey how big of a cork or plug would I need to accomadate the hole?
THanks.
-Dan.
Old Sep 29, 2002 | 10:42 PM
Scrub's Avatar
bow leggin'
I guess if you use a 20oz coke cap and match it up to a cork that would probally tell you.
Old Sep 29, 2002 | 11:16 PM
JONSKI's Avatar
-Dan.
A rubber stopper would probably work better. The Coke cap works well enough. I drink Coke while working on the car, because the caffiene helps me think. While sitting on the bench pondering about how to plug the air box nipple, I had a 20oz Coke in one hand. Guess what was in the other hand. I did it, because I wanted to fix the problem right then and there, so I improvised. I like it, because it's ghetto.
Old Sep 30, 2002 | 12:45 AM
KibagamiR2's Avatar
From: So farrrr away from the Land of the Rising Sun
I posted this in another similar post...
Heh.. noone searches anything LOL
Anyway, I bought black rubber table feet from Home Depot. They fit perfectly and tightly, and they look like they were meant to be there and do not catch the eye easily. I forget the correct diameter, just take the BOV hose to the store and find a rubber foot that matches it as closely as possible on the inside diameter and you're golden.
-Kib
Old Sep 30, 2002 | 01:12 AM
-Kib
Will do.........
Old Nov 5, 2002 | 09:52 PM
tookwik's Avatar
VIP - Very Irish Person
So, would you guys recommend this or not?
