Fuel injected 12A pics
Trending Topics
Hi!
I've been using the K-jet on my 13B for some years.. always with turbo.
Now I'm letting go of the turbo (difficulties on the carinspection) to only run it as a "Stock" engine.
The system works really good and is as you said very easy to use and cheap.
Mine came from a V6 Volvo (262 I think).
This is capable of running a ported 13B but if you are using a turbo you have to have more fule!
Here is a link to pictures of my old car with this set up.
http://ph0bic.d2g.com/magnus/turbo/
I have quite alot of experiance with this and the only thing that let me down has been a fulepump (Bosch Volvo turbo)
// Magnus
// Magnus
Conversion List
[list=1][*]GSL-SE upper manifold and throttle body[*]Audi 5000 T Fuel distributor, fuel lines w/ injectors[*]Audi 5000T fuel pump[*]Fuel filter[*]1985 VW Jetta/Golf Airbox[*]Fabricated parts include injector holders, blanking plates, throttle cable support bracket, lower aibox mods[*]Various fittings for fuel lines and oil lines[*]3" exhaust tubing[/list=1]
Thanks for the DLIDFIS idea. It works great. Injector system is basically the same as VW except came from 5 cyl turbo Audi
EDDIEROTARY:
The piece of 3" exhaust tubing is not for the exhaust. It is to connect the throttle body to the air flow sensor.
357:
Original fuel pump and filter are for a carb. The fuel injection needs a much higher pressure (75psi) and the fuel filter must be much finer to prevent the injectors and fuel distributor from clogging.
Magnus Berglund:
I remember looking at your web site. What do you use to regulate the control pressure?
357:
Magnus Berglund:
I use the stock Volvo regulator..
Have not tried anything else, but it works for me..
BTW, I'm using one injector/port and two located just under the throttle.
//Magnus
//Magnus
07-01-23 04:40 PM
